OpenWRT has gpio control binary: http://forum.openwrt.org/viewtopic.php?pid=35928#p35928
I totally agree. There's some documentation that comes with the GPL source from Broadcom that talks about the GPIO triggers and such. You might be able to find something in there. The docs that came with the sources helped me get started figuring out what goes where and how certain things work when it comes to the OS and other functions.
I'm working on new customized firmware. What is interesting, when I flash it from web interface, it is written to the router but not activized.
The web page with progress bar comes saying that reboot is in progress. It seems that it is a web page with 2 minutes javascript timer that on exit redirects back to some page. In paralel I have telnet session open. It never gets disconnected. Only when I reboot router from telnet, the new firmware is activised.
Maybe this is because of developement bug. But still - interesting,....
Hmm, maybe the open telnet session is causing the router to not reboot?
No idea why this would be the case, but the firmware code is sort of a mess
I had a problem with this on the first firmware upgrade - from 1.0.4.1 to 1.0.4.6 but since then it has worked through the web interface no problem.
Funny, I had a similar problem last night trying to flash a freshly compiled firmware. The flash of my latest & not-so-greatest compile went fine. The router reboots, and almost everything came back up (except samba, and it didn't mount the HD either ) When I flashed a previous version to get everything back in running order, all I got was the same thing. A progress bar, but as far as I could tell the router didn't do anything, nor did the 'Ready' light ever go off. Afterwards I had to shut it down and turn it back on, and it completed the flashing and all was good again.
My first attempt to add a custom boot script was semi-successful. I'm not sure where I went wrong, but I have 2 thoughts. First one is a mod I made to busybox didn't compile right, and that caused some system confusion, or it attempted to look for my custom script but where I stored it on the HD get's nuked everytime it reboots, so that threw it off. Either way it's gonna require some tinkering.
Most of the created directories will disappear upon a reboot - the source code appears to build the filesystem dynamically on power on...
Hmm, no luck with that gpio binary, I copied it across to my share, but running /share/MYVOLUME1/MYSHARE1/gpio from the router gives gpio: not found
running . gpio in the directory gives not found: ELF (then 3 diamonds)
It seems like it isn't compiled quite right for the wl-700ge...
although there is a .c source file - does anyone know how i would go about compiling this specifically for the wl-700ge?
Right, seeing as I don't appear to be able to install uclibc on my router right now, how do I go about compiling it on a linux box with glibc?
I'm messing with the 1.0.4.6 source, so it's not version specific. I'm hoping my problem had to do with the missing script I had written. I've moved it to a safer location (safe from boot-time nukings anyways) so I'll take another stab at it eventually. Right now I'm going to take a small break from trying to brick my router and try and brick my iMac. lol
Unfortunately, the provided gpio program SIGSEGV's when you try to run it - another ASUS bug I think
