fireflash - I managed to get my hard drive to spin down by modifying kfurges instructions slightly - due to the lack of the fstab, you have to define where to do the remount to:
killall -q -9 watchdog
mount -o remount,noatime,nodiratime /dev/se/2 /shares/MYVOLUME1
hdparm -S 240 /dev/ide/host2/bus0/target0/lun0/disc
smartctl -dT /dev/ide/host2/bus0/target0/lun0/disc
Change the time after -S to whatever you want to set the time before it spins down to (240 is 20minutes I believe)
I have these commands running on the rcinit startup script in MoD's firmware, so if the router gets rebooted for some reason, then the hard drive parameters still apply.
Now I have to figure out how to turn on/off the LEDS on the front - so I can sleep with it on
