Results 1 to 3 of 3
Thread: Firmware v1.0.1.6 WL566gM
    Nov 2003
    Eindhoven
    USE THIS FIRMWARE AT YOUR OWN RISK!
    Compatible with:
    WL-566gM
    Changelog:
    1. Fix: 566 didn't reinitialize if 566 is setup by EZSetup Wizard and WAN connection type is PPTP.
    2. Fix: Wireless LAN work incorrect if 566 is setup by EZSetup Wizard and adopt WEP/Shared-Key.
    3. Add: If WAN connection type is PPTP, accept heart-beat server from EZSetup Wizard.
    4. Add: Allow BitSpirit AddPortMapping or DelPortMapping.
    5. Add: PPPoE Relay support.
    6. Add: Remote syslog server support.
    7. Chg: The "WAN & LAN Filter log" is merged into "System Log"
    Download files here:
    http://website.wl500g.info/beta/wiza...firmware&id=83
    Nov 2003
    Eindhoven
    Firmware v1.0.1.7 WL566gM
    Compatible with:
    WL-566gM
    Changelog:
    1. Add: Support Simplified Chinese.
    2. Add: Support static route.
    3. Add: Add wireless access control feature.
    4. Fix: Remote management doesn't work if WAN connection type is PPTP.
    5. Chg: Upgrade Airgo AP-SDK to 2.0.4.40.
    6. Fix: UPnP AddPortMapping may fail.
    http://website.wl500g.info/beta/wiza...firmware&id=90
    Question Anyone tried this yet?
    Quote Originally Posted by Antiloop View Post
    Compatible with:
    Changelog:
    Antiloop, a couple of questions if I may:
    Do you know the specs of the wl-566gm? i.e. ROM/RAM size, cpu speed, etc.
    How do I install this firmware? Through the firmware upgrade page?
    How is the wireless connection speed and coverage and stability, cpmparing to some of the well known ones like 500gp or wl-hdd?
    Did you receive any feedback yet about this firmware from the early adoptors?
    Thank you!
  1. Firmware upgrading HOWTO
    Last Post: 30-07-2008, 22:00
  2. twonky media server, network drive with oleg firmware
    Last Post: 22-03-2006, 08:15
  3. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 13:26
  4. Flashing Oleg's Firmware in WL HDD
    Last Post: 21-10-2004, 15:55
