Hummm
From the PWC Driver F.A.Q:
My image is mirrored
This seems to happen with the PCVC730 and the Logitech cam; I have seen it myself, and it has been reported a number of times. Unfortunately I don't have a solution, and even the folks at Philips aren't sure what the problem is...
Of course that doesn't help you a lot, but at least you know you're not alone :-)
There have been a number of requests to make a 'mirror' option for the module. That is certainly possible, but that would require modifications to the PWCX module as well, including a new major number. Eventually, it will happen, no worries
Look arround Here, there was somewhere a Tool on the HP to tweak more special internal settings of the cam, i think also some which get stored permanently. Maybe you write to the Autor and post him that your cam Chipset has the same problems ...
