Take a look at Transmission packet and forget rtorrent as it has problems with wxWidgets.
I was testing torrent clients such as: ctorrent, enhenced-ctorrent or btget.
In most of the cases it's ok.
I have problem with one of the trackers that I'm using. It's refusing to connect with this clients...
Can anyone help me with compiling rtorrent client?
Thanks
if i understand you right: your tracker is blocking Clients, so you need azureus or utorrent to use it.
with enhanced-ctorrent you can fake your Client-ID
so you fake ctorrent to be azureus or utorrent or whatever u want
-p peer_id
have a look at for the IDs:
http://wiki.theory.org/BitTorrentSpecification#peer_id
hopefully it works - i haven't tested it yet...
Greetings
