Page 1 of 4 123 ... LastLast
Results 1 to 15 of 54
Thread: Problems with sharing USB disc over NFS
    Jul 2004
    near Lyon @ France
    mount -t nfs supported ?
    Hi all,
    Is nfs filesystem supported for mounting in 1.9.2.7-3 ?
    I'm trying to mount a foreign partition on my wl500g and get a "mount: 192.168.0.5:/share no such file or directory"
    Is there somethin wrong or will I have to recompile with kernel tweaked configuration ?
    Not at the moment, but this would be possible in the next firmware.
    Jul 2004
    near Lyon @ France
    Compiling kernel with nfs support
    Well,
    I'm trying harder to get nfs supported in 1.9.2.7-3 Oleg's firmware.
    Oleg said it will be supported in the next release, but I would like to try on my own. If nobody has time time to spend teaching me, that's not a problem, I will wait
    If you have time, here is my problem :
    /tmp/broadcom/src/wl500g-1.9.2.7-3c/ > make kernel
    /tmp/broadcom/src/linux/linux > make menuconfig (choose module support for NFS and support for NFS v3)
    /tmp/broadcaom/src/gateway > make
    /tmp/broadcaom/src/gateway > make install
    I the get a flashable trx with module nfs.o included
    When I try, after flashing, to load nfs.o via 'insmod nfs', I got a lot of errors about unresolved symbols and the nfs.o doesn't load. Unresolved symbols are on rpc stuff. I checked linux/linux/.config and saw that SUNRPC, LOCKD and LOCKD_V4 kernel parameters are set.
    Does anyone know what I missed ? Any tips ?
    JF
    Check your PM...
    Jan 2005
    Basel, Switzerland
    Is this now possible with the v1.9.2.7 CR4 firmware?
    mount seems to work but says "... failed: No such device".
    Markus
    Jul 2004
    near Lyon @ France
    Quote Originally Posted by bubendorf
    Yep, same thing at home. Mounting wlhdd exported partition on wl500g says "no such device".
    I have a line in /tmp/syslog.log of wlhdd (nfsd server) which says "authenticated request from xx.Xx.xx.xx for /"
    Have use all possible option with mount -tnfs -oblablah (like rsize, noroot_squash, etc...) with no effect
    wlhdd and wl500g are in their respective /etc/hosts
    Jan 2005
    Basel, Switzerland
    Searching the internet I found
    "No such device" - NFS is not configured into the client's kernel.
    I seems the kernel still does not have NFS support.
    Will this change in the near future?
    Markus
    Jan 2005
    Basel, Switzerland
    OK. I found the error. I forgot the insmods:
    insmod sunrpc
    insmod lockd
    insmod nfsd
    insmod nfs
    Now mount does not complain any more.
    But it hangs. After I typed mount -tnfs 10.0.0.3:/tmp /mnt nothing happens. Not even Ctrl-C works any more.
    Any ideas?
    Markus
    start /usr/sbin/portmap, also you do not need to insmod nfsd
    Jan 2005
    Basel, Switzerland
    It works.
    Many thanks for your answer and your great firmware.
    Markus
    Unhappy wl500gx refuses to connect nfs shares
    Hi there. As I'm not yet equipped with wl-hdd, I try some experimenting on wl500gx. However, having problems with disk space (and it's non-persistency in the case of reboot), so I tried to mount my nfs shares into /tmp/harddisk on wl500gx, but wasn't succesful yet.
    commands/logs/configuration:
    /etc/exports:
    /home/jan/nfs/asus 192.168.10(rw,no_root_squash,no_auth_nlm,insecure_ locks,async,insecure)
    - started with rw, no_root_squash options. Others were added while trying to get it working
    commands on asus:
    [admin@asus /tmp]$ mount 192.168.1.5:/home/jan/nfs/asus /tmp/harddisk
    mount: Mounting 192.168.1.5:/home/jan/nfs/asus on /tmp/harddisk failed: No such device
    /var/log/syslog (at 192.168.1.5):
    Apr 10 18:25:26 cloudcolor rpc.mountd: authenticated mount request from 192.168.1.10:658 for /home/jan/nfs/asus (/home/jan/nfs/asus)
    Apr 10 18:25:54 cloudcolor ypbind[16368]: broadcast: RPC: Timed out.
    Apr 10 18:27:08 cloudcolor ypbind[16368]: broadcast: RPC: Timed out.
    What's wrong?
    Another question is - do you think I can force asus to act as an diskless station - I mean - create root filesystem on that nfs share and chroot to it?
    Unhappy wl500gx refuses to mount nfs shares
    /etc/exports:
    commands on asus:
    What's wrong?
    Talking modules
    Problem resolved. Kernel modules sunrpc, lockd, nfs were not loaded
    A qualified guess would be that the NFS file system is not compiled in the kernel, but that the utilities know about it, allowing the mount call to succeede but the registration i nthe kernel failed.
    Try 1.9.2.7-5, it will probably fix your problems.
    Last Post: 14-03-2012, 16:28
  2. Unstable boot from USB
    Last Post: 20-08-2008, 16:19
  3. WL500g 2 USB Drucker und ein LPT
    By Trebron in forum German Discussion - Deutsch (DE)
    Last Post: 28-01-2006, 00:48
  4. Wl500g > 2 USB and 1 LPT Printer
    By Trebron in forum WL-500g Q&A
    Last Post: 27-01-2006, 23:17
  5. Please help... USB HDD doesn't work
    By jirina42 in forum WL-500g Q&A
    Last Post: 05-01-2006, 20:04
