Maybe. If you can find a version of the driver ported to the Linux on the router, or do it yourself.
1. I have a Avaya Wireless USB-client card.
2. My Asus WL-500gP has a USB port.
3. I have the Avaya card working in SuSE Linux 10.1
4. Asus WL-500gP runs Linux.
So, the question is:
Is it at all possible to hook up the Avaya USB card to the Asus, use the driver I use on SuSE (modded maybe), and in effect have two wireless devices on the Asus?
Thanks!
Tor Arne
2x Mitsubishi R100 (Same old WL-500g, different box, different firmware), running OpenWRT.
