Originally Posted by
Timocracy
I just flashed olegs latest firmware on my wl500gP.
Then I followed the tutorials of marcnesium and r0kanon.
So far so good, up to the point where I shall mount my data partition (yes I took part1 (64mb) as swap and part2 (ca 150GB) for data).
But when I try to mount part2 on /opt it says:
[admin@(none) root]$ mount /dev/discs/disc0/part2 /opt
mount: Mounting /dev/discs/disc0/part2 on /opt failed: Invalid argument
And also when I type in "fdisk -1" it get this response:
[admin@(none) root]$ fdisk -1
fdisk: illegal option -- 1
BusyBox v1.1.3 (2006.06.29-17:07+0000) multi-call binary
Usage: fdisk [-luv] [-C CYLINDERS] [-H HEADS] [-S SECTORS] [-b SSZ] DISK
What can I do to make it work correctly? I tried the process a few times, but it never worked.
