Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 78
Thread: [USB] Webcams
  1. #46
    Thumbs down Logitech QuickCam Communicate STX
    Tested@
    Model: WL-500g deluxe
    Firmware: 1.9.2.7-7b Oleg
    Device NOT WORKING
    Brandname: Logitech
    Brandtype: QuickCam Communicate STX
    USB Interface: USB 1.1 compliant
    System log:
    Jan 1 01:16:20 USB webcam: attached
    Jan 1 01:16:21 kernel: pwc Philips PCA645/646 + PCVC675/680/690 + PCVC730/740/750 webcam module version 8.12 loaded.
    Jan 1 01:16:21 kernel: pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
    Jan 1 01:16:21 kernel: pwc the Creative WebCam 5, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
    Jan 1 01:16:21 kernel: usb.c: registered new driver Philips webcam
  2. #47
    Thumbs down
    Tested@
    Firmware: 1.9.2.7-7a Oleg
    Device NOT WORKING
    Brandname: Genius
    Brandtype: VideoCAM Trek v 2.0
    System log:
    Jan 1 01:00:07 kernel: hub.c: new USB device 01:02.0-2, assigned address 2
    Jan 1 01:00:08 kernel: usb.c: USB device 2 (vend/prod 0xc45/0x6007) is not claimed by any active driver.
  3. #48
    Logitech Quickcam Zoom
    Tested@
    Device partly WORKING but generally said it DOESN'T WORK
    Brandname: Logitech
    Brandtype: QuickCam Zoom
    If the device IS connected to Asus while it's been turning on it mostly works (just in low resolution). There's a problem with security alerts.
    In fact I look for another webcam...
  4. #49
    Canyon webcam NOT Working
    Tested: NOT WORKING!
    Model: WL-500g
    Firmware: 1.9.5.0
    Device:
    Brandname: Canyon
    USB Interface: 1.1
    info:
    Sensor Res: 300 pixel
    Technology: CMOS
    Optical Sensor: 1/5"
    Max. image res: 352x288
    URL To manufacturer: http://www.canyon-tech.com/
    URL To product: http://www.canyon-tech.com/products/...meras/CN-WCAM1
  5. #50
    GENIUS VideoCAM GE111 & VideoCAM Look
    Device NOT WORKING
    Brandname: Genius
    Brandtype: VideoCAM GE111
    kernel: hub.c: new USB device 01:02.0-2, assigned address 3
    kernel: usb.c: USB device 3 (vend/prod 0x93a/0x2471) is not claimed by any active driver
    Device NOT WORKING
    Brandname: Genius
    Brandtype: VideoCAM Look
    kernel: usbaudio: device 3 audiocontrol interface 1 has 1 input and 0 output AudioStreaming interfaces
    kernel: usbaudio: device 3 interface 2 altsetting 1 channels 1 framesize 2 configured
    kernel: usbaudio: valid input sample rate 8000
    kernel: usbaudio: device 3 interface 2 altsetting 1: format 0x00000010 sratelo 8000 sratehi 8000 attributes 0x00
    kernel: usbaudio: registered dsp 14,3
    kernel: usbaudio: no mixer controls found for Terminal 2
    USB audio: attached
  6. #51
    Tested@
    Device NOT WORKING
    Brandname: SilverCrest ( die vom Lidl )
    Brandtype: WebCam compliant1,3MPix
    USB Interface: USB 2.0
    System log:
    Mar 18 18:20:51 kernel: hub.c: new USB device 01:02.0-1, assigned address 3
    Mar 18 18:20:51 kernel: usb.c: USB device 3 (vend/prod 0x93a/0x2600) is not claimed by any active driver.
    URL To manufacturer:http://www.mysilvercrest.de
    URL To product:http://www.mysilvercrest.de/de/artikel.php?a=79
  7. #52
    MSI StarCam 370i
    Firmware: 1.9.2.7-7c Oleg
    Device NOT WORKING
    Brandname: MSI
    Brandtype: StarCam 370i
    Jan 1 00:00:06 kernel: usb.c: registered new driver usbdevfs
    Jan 1 00:00:06 kernel: usb.c: registered new driver hub
    Jan 1 00:00:06 kernel: usb-uhci.c: $Revision: 1.275 $ time 21:43:09 Apr 20 2005
    Jan 1 00:00:06 kernel: usb-uhci.c: High bandwidth mode enabled
    Jan 1 00:00:06 kernel: PCI: Enabling device 01:02.0 (0000 -> 0001)
    Jan 1 00:00:06 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
    Jan 1 00:00:06 kernel: usb-uhci.c: Detected 2 ports
    Jan 1 00:00:06 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan 1 00:00:06 kernel: hub.c: USB hub found
    Jan 1 00:00:06 kernel: hub.c: 2 ports detected
    Jan 1 00:00:06 kernel: PCI: Enabling device 01:02.1 (0000 -> 0001)
    Jan 1 00:00:06 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
    Jan 1 00:00:06 kernel: usb.c: new USB bus registered, assigned bus number 2
    Jan 1 00:00:06 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
    Jan 1 00:00:06 kernel: PCI: Enabling device 01:02.2 (0000 -> 0002)
    Jan 1 00:00:06 kernel: ehci_hcd 01:02.2: PCI device 1106:3104
    Jan 1 00:00:06 kernel: ehci_hcd 01:02.2: irq 2, pci mem c00a6000
    Jan 1 00:00:06 kernel: usb.c: new USB bus registered, assigned bus number 3
    Jan 1 00:00:06 kernel: PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
    Jan 1 00:00:06 kernel: ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
    Jan 1 00:00:07 kernel: hub.c: USB hub found
    Jan 1 00:00:07 kernel: hub.c: 4 ports detected
    Jan 1 00:00:07 kernel: usb.c: registered new driver usblp
    Jan 1 00:00:07 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan 1 00:00:07 kernel: hub.c: connect-debounce failed, port 1 disabled
    Jan 1 00:00:08 kernel: hub.c: new USB device 01:02.0-1, assigned address 2
    Jan 1 00:00:08 kernel: usb.c: USB device 2 (vend/prod 0xc45/0x60c0) is not claimed by any active driver.
    Jan 1 00:00:08 USB audio: attached
    Jan 1 00:00:08 kernel: usb.c: registered new driver audio
    Jan 1 00:00:08 kernel: usbaudio: device 2 audiocontrol interface 1 has 1 input and 0 output AudioStreaming interfaces
    Jan 1 00:00:08 kernel: usbaudio: device 2 interface 2 altsetting 1 channels 1 framesize 2 configured
    Jan 1 00:00:08 kernel: usbaudio: valid input sample rate 8000
    Jan 1 00:00:08 kernel: usbaudio: valid input sample rate 16000
    Jan 1 00:00:08 kernel: usbaudio: device 2 interface 2 altsetting 1: format 0x00000010 sratelo 8000 sratehi 16000 attributes 0x01
    Jan 1 00:00:08 kernel: usbaudio: registered dsp 14,3
    Jan 1 00:00:08 kernel: usbaudio: warning: found 1 of 0 logical channels.
    Jan 1 00:00:08 kernel: usbaudio: assuming the channel found is the master channel (got a Philips camera?). Should be fine.
    Jan 1 00:00:08 kernel: usbaudio: registered mixer 14,0
    Jan 1 00:00:08 kernel: audio.c: v1.0.0:USB Audio Class driver
    Jan 1 00:00:09 kernel: Linux video capture interface: v1.00
    Jan 1 00:00:09 kernel: SCSI subsystem driver Revision: 1.00
    Jan 1 00:00:10 kernel: Initializing USB Mass Storage driver...
    Jan 1 00:00:10 kernel: usb.c: registered new driver usb-storage
    Jan 1 00:00:10 kernel: USB Mass Storage support registered.
  8. #53
    Apr 2006
    Heesch, Netherlands
    Philips ToUcam II (pcvc820K)
    Device WORKING
    Brandname: Philips
    Brandtype: ToUcam II (pcvc820K)
  9. #54
    May 2006
    Netherlands
    Thumbs down
    Model: WL-700gE
    Firmware: 1.0.4.1
    Device: NOT WORKING
    Brandname: Logitech
    Brandtype: Sphere
    When connected, the light goes on, but it only captures 1 shot and then it's just not refreshed. And also, the picture is in B/W instead of colour
    My current collection:
    WL-500gX (original firmware), WL-500gX (Oleg 1.9.2.7-7g), WL-500gX (Oleg 1.9.2.7-8), WL-700gE (Asus 2.0.0.7)
  10. #55
    Btc Pc-380
    Model: BTC PC-380
    Firmware: 1.0.4.1
    Device: NOT WORKING
    Brandname: BTC
    Brandtype: PC-380
    Product URL: http://www.btc.com.tw/english/2-9-5camera.htm#380
  11. #56
    Tested@
    Model: WL-500gx
    Firmware: 1.9.5.0
    Device NOT WORKING >:E
    Brandname: Trust
    Brandtype: SpaceCam 150
  12. #57
    Model: WL-500g
    Firmware: 1.9.2.7-7e Oleg
    Device NOT WORKING
    Brandname: Medion (ALDI)
    Brandtype: MD 85081 (PC-30)
  13. #58
    Angry Not Working Ms-tech Lv-310
    tested@
    Model: WL-500gx
    Device NOT WORKING
    Brandname: MS-TECH
    Brandtype: LV-310
    Product URL: Click Here
    dmesg output:
    hub.c: new USB device 01:02.0-1, assigned address 5
    usb.c: USB device 5 (vend/prod 0x4fc/0x561) is not claimed by any active driver.
    Sash
  14. #59
    May 2006
    Netherlands
    Thumbs up
    Model: WL-500gx
    Device: WORKING
    Brandname: Logitech
    Brandtype: Sphere
    As the WL-700gE disappointed me I bought a second-handed WL-500gx which works quite allright
  15. #60
    Logitech sphere / orbit / tpz
    Model: WL-500g
    Device: NOT WORKING
    Brandname: Logitech
    Brandtype: Sphere
    Everybody wrote this device working! And my config didn't work!
    Please help!
    Router:
    Jan 1 01:00:03 kernel: usb.c: new USB bus registered, assigned bus number 1
    Jan 1 01:00:03 kernel: hub.c: USB hub found
    Jan 1 01:00:03 kernel: hub.c: 2 ports detected
    Jan 1 01:00:04 kernel: hub.c: new USB device 00:04.0-1, assigned address 2
    Jan 1 01:00:04 kernel: lp0: using parport0 (polling).
    Jan 1 01:00:04 kernel: usb.c: USB device 2 (vend/prod 0x46d/0x8c2) is not claimed by any active driver.
    Jan 1 01:00:04 USB webcam: attached
    Jan 1 01:00:04 kernel: usb.c: registered new driver usblp
    Jan 1 01:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
    Jan 1 01:00:07 kernel: usb.c: registered new driver audio
    Jan 1 01:00:07 kernel: usbaudio: device 2 audiocontrol interface 2 has 1 input and 0 output AudioStreaming interfaces
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 1 channels 1 framesize 2 configured
    Jan 1 01:00:07 kernel: usbaudio: valid input sample rate 0
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 1: format 0x00000010 sratelo 0 sratehi 0 attributes 0x01
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 2 channels 1 framesize 2 configured
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 2: format 0x00000010 sratelo 0 sratehi 0 attributes 0x01
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 3 channels 1 framesize 2 configured
    Jan 1 01:00:07 kernel: usbaudio: valid input sample rate 16000
    Jan 1 01:00:07 kernel: usbaudio: device 2 interface 3 altsetting 3: format 0x00000010 sratelo 16000 sratehi 16000 attributes 0x01
    Jan 1 01:00:07 kernel: usbaudio: registered dsp 14,3
    Jan 1 01:00:07 kernel: usbaudio: warning: found 1 of 0 logical channels.
    Jan 1 01:00:07 kernel: usbaudio: assuming the channel found is the master channel (got a Philips camera?). Should be fine.
    Jan 1 01:00:07 kernel: usbaudio: registered mixer 14,0
    Jan 1 01:00:07 kernel: audio.c: v1.0.0:USB Audio Class driver
    Jan 1 01:00:08 kernel: Linux video capture interface: v1.00
    Jan 1 01:00:08 kernel: pwc Philips webcam module version 9.0.2 loaded.
    Jan 1 01:00:08 kernel: pwc Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
    Jan 1 01:00:08 kernel: pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
    Jan 1 01:00:08 kernel: pwc the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
    Jan 1 01:00:08 kernel: pwc Default image size set to vga [640x480].
    Jan 1 01:00:08 kernel: usb.c: registered new driver Philips webcam
    Jan 1 01:00:09 kernel: SCSI subsystem driver Revision: 1.00
    Jan 1 01:00:09 kernel: pwc Philips webcam decompressor routines version 9.0-BETA-2
    Jan 1 01:00:09 kernel: pwc Supports all cameras supported by the main module (pwc).
    Jan 1 01:00:10 kernel: Initializing USB Mass Storage driver...
    Jan 1 01:00:10 kernel: usb.c: registered new driver usb-storage
    Jan 1 01:00:10 kernel: USB Mass Storage support registered.
  1. WebCam - SPCA50x drivers
    By lada in forum WL-500g Custom Development
    Last Post: 19-06-2009, 14:59
