w500g and wl-hdd with oleg firmware doesn't work with WIFI
Hello !!
First, sorry my english.
I have a wl500g and a wl-hdd. i applied oleg firmware 1.9.2.7-7e successfully.
set up samba and ssh daemon. Everithing work fine when wl-hdd connect by cable.
But when i pull off the LAN cable no connection any more.
The bridge mode is hybrid both device, the channel is same both device.
Connect AP (yes) allow anonymous (no) both device
the mac address filled correctly. (wl500g contain the wl-hdd mac and vice versa)
ssid is same both device,
I use wpa-psk tkip both device
Can anybody help me ??
what is wrong in my setup
- You may not post replies
- You may not edit your posts
Forum Rules
