Hello everyone,
I recently bought a wireless router and an Access point from asus, because of the good reviews they received. However i am having a problem putting this things to work. And the manual does not help.
I lost almost 2 hours just to get acess to the router configuration, (they forgot to tell you in the manual you must connect the cable to the LAN1 port insted of the first port WAN). I don't know if the two devices must have 2 different IP numbers or if you just can use them with the assigned default IP numbers, wich are equal in both devices. I have acctually changed the Default Ip in the AP to XXX.XXX.X.2, insted of XXX.XXX.X.1, but after i do that i can't acess it anymore (I changed the Ip in windows too so it matches the new one in the AP) and must reset the AP afterwards to gain acess to it again. And even if i use all the default IP numbers, how am i suposed to detect if there are any wifi devices nearby? The device detector program only finds the one directly connected to the computer by cable (AP or router).
Please Help!
