with no security enabled I can successfully connect together my two wl500gs. The one connected to WAN runs the DHCP, the second one gets an IP for itself and forwards DHCP requests of clients as it should.
I do not see the routers listed in Status&Log/wireless (router is not even listed and especially not authorized) however in dhcp leases i can find the second router.
So everything runs fine besides no entries in status in unsecured mode.
As soon as i enable WPA-PSK TKIP+AES nothing works anymore. Second router doesnt fetch itself an IP and hence all clients behind the second routers are not even able to connect to it as they also get no IP.
Both run 1.9.5, same ssid, same channel, macs assigned in the bridge menu. same WPA-PSK properties+pass.
any help?
how can I open that shell again where i can type in wl commands. Is there a way to find out what happens? (whether the routers at least try to communicate and what fails?)
thanks heiner
