Results 1 to 3 of 3
Thread: Custom firmware image: v1.9.4.6 with telnetd re-enabled
    This custom firmware image re-enables telnetd in 1.9.4.6.
    http://www.bitsum.com/files/wl530g/W...-telnet_EN.bin
    The next one I release will have a better busybox, and whatever else you guys want me to put in it. I can base it off the newer beta firmware images if you desire. I can port virtually any package to these units, and am making the procedure easy for anyone via updates to my Firmware Modification Kit.
    If anyone has any interest in these units, please let me know. Again, my current work is here: http://www.bitsum.com/openwiking/owb...p?WL%2D530G#h2 (changing rapidly)
    Jeremy
    differences
    Hello db90h,
    what is the difference between this telnet enabled firmware and the latest build from your webpage? As far as I understand telnet is enabled in the latest build too.
    best regards robert
    PPPoE and Service name
    I am using PPPoE to access Internet.
    My provider requires Service name. Without service name no authorization.
    I got Assus wl530g - and of course there weren't this field.
    I got also Linksys - wrt54g. Same problem. I installed on Linksys firmware from dd-wrt, and I got that problem solved - using Service name as my provider require.
    Unfortunately from support centers (Assus && Linksys) I got similar responses - you don't need this feature*, but I need it.
    For some time I used computer (as router) and routers only as access points (which is stupid, but routers have no service name). I installed PPPoE connection on Windows XP, Gentoo Linux, FC6 etc - all the time without Service name - connection refused.
    I have some experience with Linux but almost no experience with embedded Linux.
    I will greatly appreciate any help with Service name - only don't tell me I dont need it. I need it.
    __________
    *And a lot of even more stupid "help"
  1. WL-500g custom firmware tutorial for beginners (norwegian)
    By Bertie in forum WL-500g/WL-500gx Tutorials
    Last Post: 05-09-2006, 13:47
  2. Any luck using custom firmware on WL-700gE?
    By hernidez in forum WL-700g Firmware Discussion
    Last Post: 05-06-2006, 14:11
  3. custom firmware based on 1.9.5.0 beta?
    By Teddy in forum WL-500g Custom Development
    Last Post: 14-05-2006, 20:08
  4. Custom firmware
    By menno in forum Dutch Discussion - Nederlands
    Last Post: 02-04-2006, 14:32
  5. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 12:26
