Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 108
Thread: WL-500gP with 3G USB Modem and Oleg's Firmware
    Modem USB huawei e200
    last week i brought a asus wl-500g Premium.
    I flashed with firmware h**p://koppel.cz/cdmawifi/download/163/WL500gp-1.9.2.7-7f-USB-1.63.trx
    my usb modem Huawei e200, is recognized but can't establish a connection.
    I need help, please!
    I have the same problem. Firmware from mentioned website is only for ZADACOM modems and will not support HUAWEI modems. I contacted people around the project, if there is a possibility to create firmware, that will support this modem, but had negative answer. They did not have that modem, it is quite expensive to get it. Without having the modem physically at their site, they cannot develop the firmware update.
    Now, waiting for some developer, who will have the modem and will modify the firmware by loading appropriate usbserial modules, that will support HUAWEI modem.
    Please uninstall the zadacomm drivers with the rmmod command and execute insmod usbserial vendor=0x12d1 product=0x1003
    Then use pppd and chat to make the connection.
    Hope this helps..
    Cheers
    Asus WL-500g DELUXE...does the same things as Premium? Good for 3g modems?
    I can buy the Deluxe version for a few euros, is it customizable like the Premium??? Will I be able to use it with Huawei e220 usb modem at full speed??
    thank you
    ps: first post
    pps: I discovered yesterday this fantastic router and I am very happy because I can save a lot of money! In fact, I thought that I would have to buy the super-expensive Linksys WRT54G3G-EU to share a 3g connection!! Instead I found this beautiful router wich cost only 70euros! A lot of people out there DON'T KNOW that you can use a 3g usb modem attached to these cheap routers and they buy the linksys for 170+ euros!! (to use it with a pcmcia 3g modem)
    Jul 2007
    Austria
    Definitely yes!
    But read carefully http://wl500g.info/showthread.php?t=...ei+E220&page=2
    So it means you have to install 3rd party firmware and follow tutorials.
    Edit: Premium is a bit better, faster cpu 266mhz instead of 200 mhz and
    8MB flash instead of 4MB. Ram is the same= 32 MB.
    Premium costs about 70 Euro.
    Thank you.
    I knew I would have to use "custom" firmwares and to follow tutorials for both the routers.
    Maybe I can get the deluxe for less than 40euros (used), that's why I was wondering whether to buy the deluxe or the premium...the deluxe is half the price....I don't know...maybe I'll get the premium eventually....
    Meanwhile I think I should learn a bit of LINUX because most of those tutorials are non-sense to me!
    How to make WL-500 and Huawei E220 work?
    I have a problem to get Huawei E220 co-operating with WL-500 gP.
    I have Oleg's 1.68 in my WL-500gP and I installed the user dial up files for Huawei seemingly OK. The Asus menu says it is using Huwei E222 and the dial settings are the same that work with Zadacom modem.
    Anyway, I cannot get connected. When I plug in the modem, I have the system log:
    Jan 1 02:01:57 kernel: hub.c: new USB device 01:03.0-1, assigned address 2
    Jan 1 02:01:57 kernel: usb.c: USB device not accepting new address=2 (error=-145)
    Jan 1 02:01:57 kernel: hub.c: new USB device 01:03.0-1, assigned address 3
    Jan 1 02:01:57 kernel: usb.c: USB device not accepting new address=3 (error=-145)
    Jan 1 02:02:18 pppd[207]: In file /tmp/ppp/peers/gprs: unrecognized option '/dev/usb/tts/0'
    Any ideas what I could do to make this work? Thanks in advance.
    Jul 2007
    Austria
    Install fw again resp. use 1.68 and this howto:
    http://translate.google.com/translat...hl=de&ie=UTF-8
    have fun.....
    One step forward: I updated the firmware of the E220 and now Asus recognizes it - as a CD ROM!
    So I have now a Huawei CD-ROM in my WL-500, and the "dial script failed" in my system log .
    Jul 2007
    Austria
    Ok, use this one.....http://wl500g.info/showthread.php?p=88053#post88053
    my E220 modem works perfect.
    hi friends,
    I have this problem with a vodafone connect box E220 with the last firmware and all the howto and oleg firmware version
    When I plug in the power in Asus Wl 500GP it don't detect usb /dev/usb/tts/0ports of the modem E-220.
    If i reboot the router WL-500GP it already detects de usb tts/0 off E-220 and make the connection to internet
    Conclusion :
    if i power on the router, it dosen't detect the ports of Hauwei E-220 and don't make the connection to Internet
    If i reboot the router without disconnnect the power of it, it will make the connection to the internet
    can anyone help me ??
    I try everyting
    huawei E-220 Vodafone P and Oleg's Firmware
    hi friends,
    Conclusion :
    I try everyting
    Jul 2007
    Austria
    Just add to your post-boot a 'sleep 30' at the end (or if optware is installed, before calling rcunslung)
    And check out USB vendor/device ID (12d1:1003)
    have fun
    Jul 2007
    Austria
    Add a 'sleep 30' to your post-boot
    Thanks for your support. I did all again from scratch including post-boot sleep etc. I also flashed the E220 to the newest Vodafone SW.
    I still have the same notice in the system log like xipbox, but the difference is that I cannot connect in any combination of reboot, POR etc. I even tried a powered USB hub in between thinking of power problems that E220 is often having.
    The Oleg's version is now 168a, should this work as well?
    Could some firmware other than Vodafone version work better?
    And what is this stuff about "USB device not accepting new address"? Can anybody tell?
  1. New oleg firmware version
    By Lesiuk in forum WL-500gP Firmware Discussion
    Last Post: 13-05-2016, 04:55
  2. RT-N10U B is supported by oleg firmware?
    By Jeony in forum English Discussion
    Last Post: 10-05-2013, 07:44
  3. Oleg firmware - older version
    By kvr in forum WL-500gP Firmware Discussion
    Last Post: 17-04-2012, 19:04
  4. Real time clock with Oleg's firmware
    Last Post: 21-04-2009, 09:20
    Last Post: 21-10-2004, 14:55
