Page 1 of 8 123 ... LastLast
Results 1 to 15 of 108
Thread: WL-500gP with 3G USB Modem and Oleg's Firmware
    Lightbulb WL-500gP with 3G USB Modem and Oleg's Firmware
    Hello,
    I'm new in this land, but i want to question if someone nows if exist any firmware with CDMA to ASUS WL-500gP, and where I can find it.
    Thanks,
    JF
    Aug 2006
    Lisbon / Portugal
    Quote Originally Posted by [Lamas] View Post
    Hello,
    Thanks,
    JF
    Hi, I am using the ASUS WL-500gP ith the firmware I found at this site:
    http://koppel.cz/cdmawifi/download/162/
    and it works perfectly with my CDMA USB modem.
    The firmware is in english, but since the site is in Check and I dont understand
    this language it was kind of trial and error.
    Bur so far so good.
    Mektub
    Quote Originally Posted by Mektub View Post
    The firmware is in english, but since the site is in Check and I dont understand this language it was kind of trial and error.
    Mektub
    Check that this site is in "Czech"
    Oct 2004
    Portugal
    WL500gp-1.9.2.7-7f-pre5-CDMA-1.62.trx work well for me too, but this firmware are secure? I don't want my wl-500gp dead..
    And with the problem about the range of 500gP? my 500g have more that twice range that 500gP.
    And in the box say it more that 300% range..
    Home Page
    Marco Sousa from PORTUGAL
    Oct 2004
    Portugal
    This cdma fw have some bugs that it need to be fixed
    I can't use Dynamic DNS Say:
    ddns update: could not resolve ip address for vlan1.
    It seems easy to solve..
    Home Page
    Vodafone 3G USB Modem, help!
    Hello, I want to buy a 3G USB Modem to have internet everywhere but when I am at home I have another computers and I want to share my connection without having one computer turned on to share the internet! I looked for intensively in the Internet and finnaly I found one router called Asus WL-500g deluxe with 2 Usb Ports that works with one ISP from Portugal called ZAPP, so my awnser is if this works with the Vodafone USB 3G Connection Box.
    Here you have a photo of it.
    Hope you can help me!
    Thanks!
    Yes, the Asus WL500g Deluxe works with that dongle (I'm assuming you are talking about the Huawei E220 - a.k.a. Vodafone SmartModem). But it doesn't work out of the box, you need to load the usbserial module manually (or in /usr/local/sbin/post-boot) and configure the dialup settings. Other than that it works (don't expect HSDPA speeds though, that won't happen until someone recompiles the usbserial module for the WL500g with the extensions suggested at http://www.junxion.com/opensource/li...usbserial.html - there's another thread I opened on the subject earlier).
    Razvan
    That's the one I'm using and it doesn't help much. The USB Serial module is still the same slow one, they're using the acm module for the EVDO modems. I'm in Romania and we have a CDMA 450 EVDO network here so I was able to test. You still need to insert the module manually and you still get slow speeds.
    Oct 2004
    Portugal
    A new release with the last and final firmware of OLEG, and with the bugs I reported fixed.
    http://koppel.cz/cdmawifi/download/163/
    The changes 1.62 to 1.63:
    1.63
    * priprava uzivatelskych scriptu v /usr/local/sbin
    * moznost zadani username/password/apn pro IP Wireless (T-Mobile 4G)
    * podpora GPRS/EDGE/UMTS/HSDPA modemů Zadacom 2G a 3G+
    * opravy spravy DNS v zalohovanem spojeni
    * funkcni DDNS (dyndns) pro vytacena spojeni se zjistovanim skutecne vnejsi ip adresy
    * Changes of OLEG:
    * Switched to Busybox 1.1.3
    * VT6212 USB 2.0 patch (10-15% speedup)
    * USB sticks without MBR should be also now mounted
    * Storage devices are using async options by default
    * WL500g Premium support (MirrorBit Flash support, nvram validation, 32mb enabled) !!! The firmware is totally different from the stock one: no DM, different FTP server and Samba! Do not flash if in doubt - you would miss some features !!!
    * Additional pppd options field is now 255 chars long
    * PPP now defaults to unlimited number of connection attempts
    * PPTP connections now use MTU 1400 by default
    * DHCP+PPTP (0.0.0.0 gateway support in the MAN routes, DNS and default gateway options now could be acquired from DHCP too, symbolic PPTP name support, PPTP client now adds route to the server)
    * Fixed MAN->LAN firewall issue (be sure to enable WAN to LAN filter and set default action to DROP!)
    * Fixed some firewall defaults (WAN->LAN is now enabled and DROPs)
    * "Apply to routing table" option is now in effect
    * Default gateway is no longer appears in the nameserver list in the AP mode
    * SIGALRM is no longer blocked in the post-mount
    * Minor bugs...
    Home Page
    Jan 2006
    Jakarta, Indonesia
    Hi Mektub,
    May i know what CDMA Modem do you use with WL-500gP ?
    Thank you ..
    My ASUS Collection :
    WL-520g, WL-500g Deluxe, WL-100g Deluxe, WL-167g, WL-130b, A3L Notebook.
    Aug 2006
    Lisbon / Portugal
    Quote Originally Posted by yapit View Post
    Hi Mektub,
    Thank you ..
    The modem comes in a pack when you subscribe to ZAPP, a company that operates in Portugal and several other countries. They call it Z010, but I think it is a 'Qualcomm CDMA Technologies MSM'.
    They now deliver another modem called Z020 but I suppose those are internal names from Zapp.
    They look like this:
    Oct 2004
    Portugal
    I use the same modem Z010 from Zapp Portugal.
    --Usb Adaptor--
    P: Vendor=05c6 ProdID=3196 Rev= 0.00
    S: Manufacturer=Qualcomm, Incorporated
    S: Product=Qualcomm CDMA Technologies MSM
    Firmware : AA3.3.30 NM20RM3026 ^A
    Power state : 85% (battery)
    Signal : -0dB
    Hybrid mode : CDMA+HDR
    ---=== Details ===---
    Software Version : NM20RM3026A
    Compile Date : r 12 20051
    Compile Time : :14:29*
    Station Class Mark : 0x06
    Mobile CAI Revision : 0x5F
    Mobile Model : 0x04
    Firmware Revision : 0x0102
    Slot Cycle Index : 0x00
    Demodulator ID : 0x0100
    Decoder ID : 0x00
    Interleaver ID : 0x6B
    Rx Automatic Gain Control : 0x
    Tx Automatic Gain Control : 0x
    Tx Gain Adjust : 0x
    Pilot Strength (Ec/Io) : 0x
    Current Sleep Signal : 0x
    PN Offset Array :
    HDR Connection : ???
    Home Page
    Z020 == AnyDATA ADU-E100A(?D) (h**p://www.anydata.com/PRODUCTS/adu100.html OR h**p://www.anydata.com/PRODUCTS/adue100d.html)
    Does it work with 500gp? I heard, that it badly works in Linux.
    Aug 2006
    Lisbon / Portugal
    Quote Originally Posted by KyRT View Post
    The z010 with the software mentioned above by Int works very well.
    And in fact I use Linux. Linux only sees the 500gp, it is unaware of the z010. The 500gp handles the dialing and normally i leave it connected several days on a row.
    Mektub
  1. New oleg firmware version
    By Lesiuk in forum WL-500gP Firmware Discussion
    Last Post: 13-05-2016, 04:55
  2. RT-N10U B is supported by oleg firmware?
    By Jeony in forum English Discussion
    Last Post: 10-05-2013, 07:44
  3. Oleg firmware - older version
    By kvr in forum WL-500gP Firmware Discussion
    Last Post: 17-04-2012, 19:04
  4. Real time clock with Oleg's firmware
    Last Post: 21-04-2009, 09:20
    Last Post: 21-10-2004, 14:55
