the crossover cable didn't work. the WAN to belkin LAN connection did show some packets getting through the WAN port but I still couldn't get a DHCP.Originally Posted by Oleg
[admin@(none) root]$ ifconfig
br0 Link encap:Ethernet HWaddr 00:30:BD:9C:62:CE
inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0
RX packets:105 errors:0 dropped:0 overruns:0 frame:0
TX packets:37 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:9120 (8.9 KiB) TX bytes:2370 (2.3 KiB)
eth0 Link encap:Ethernet HWaddr 00:30:BD:9C:62:CE
TX packets:53 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:11010 (10.7 KiB) TX bytes:3330 (3.2 KiB)
Interrupt:3 Base address:0x2000
eth1 Link encap:Ethernet HWaddr 00:30:BD:9C:62:CF
RX packets:57 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7623 (7.4 KiB) TX bytes:1812 (1.7 KiB)
Interrupt:4 Base address:0x8000
eth2 Link encap:Ethernet HWaddr 00:30:BD:9C:62:CE
RX packets:0 errors:0 dropped:0 overruns:0 frame:45
TX packets:74 errors:5 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:9162 (8.9 KiB)
Interrupt:6 Base address:0x2000
lo Link encap:Local Loopback
I tried connecting the belkin to the motorola wr850g wirelessly by setting the belkin to "client mode". I could see the belkin MAC address in the motorola web interface but I could not get a dhcp.
I thought this might be related to the WAN port not getting a dhcp since the WLAN port gets switched with the WAN port in client mode.
the belkin wireless port works in AP mode. I connected to the belkin with a usb wireless radio and it gets assigned an IP by the belkin.
the belkin lan port also works correctly.
Could this still be a problem with the nvram setting or is it that the asus kernel is not compatible with the belkin?
