Originally posted by Snigel
Does fcc rules apply outside america?
How high is the transmit power before and after? What are the limitations?
Aren't we able to disable the watchdog by the way?
as fas as I know the fcc rules do not apply outside america, but here in the netherlands we are limited to the 100mW stuff (measured in more things only than transmitting power)
what do you mean about transmit power before and after ?
the watchdog cannot be disabled in it's current state, because when the watchdog is closed down, the router is instructed to restart.
try to kill the watchdog and see for yourself
ps ax from system command:
PID Uid VmSize Stat Command
1 0 1848 S init
2 0 S [keventd]
3 0 S [ksoftirqd_CPU0]
4 0 S [kswapd]
5 0 S [bdflush]
6 0 S [kupdated]
7 0 S [mtdblockd]
222 0 1824 S syslogd -m 0 -O /etc/linuxigd/syslog.log -t MET-1ME
226 0 1836 S klogd
485 0 1472 S /usr/sbin/udhcpd /tmp/udhcpd.conf
512 0 S [khubd]
638 0 1424 S /sbin/prnsvr
639 0 1432 S /sbin/infosvr br0
644 0 1844 S /bin/sh /init/rc.watchdog ROUTER
645 0 1852 S /bin/sh /init/upnpserver eth1
669 0 2456 S upnp -D -L br0 -W eth1
671 0 1464 S udhcpc -i eth1 -p /var/run/udhcpc.pid -s /usr/share
713 0 2644 S nas /tmp/nas.conf
724 0 1444 S /usr/sbin/watchdog 30 131.107.1.10 MET-1METDST 0 0
929 0 1464 S /sbin/dproxy -c /etc/dproxy.conf
9707 0 1556 S httpd
9715 0 1824 S sleep 30s
9716 0 1828 S sh -c ps ax > /etc/linuxigd/syscmd.log
9717 0 1828 R ps ax
. /etc/linuxigd/LANHostConfig
. /etc/linuxigd/PrinterStatus
. /etc/linuxigd/FirewallConfig
# In AP mode, there is no syslogd/klogd/ntp client
# echo to console for manufacturer
echo "PaN&&&"
sleep 3s
ifconfig lo 127.0.0.1
if [ -f "/tmp/nas.conf" ]; then
#nascmd=`cat /tmp/nas.conf`
nas /tmp/nas.conf &
if [ "$1" != "AP" ]; then
if [ "$x_WSecurity" = "1" ]; then
Active1="$x_WSecurityDate $x_WSecurityTime"
Active1="0 0"
if [ "$UrlFilterEnable" = "1" ]; then
Active2="$URLActiveDate $URLActiveTime"
Active2="0 0"
if [ "$WanLanFirewallEnable" = "1" ]; then
Active3="$WanLanActiveDate $WanLanActiveTime"
Active4="$LanWanActiveDate $LanWanActiveTime"
Active3="0 0"
Active4="0 0"
if [ "$WanLocalFirewallEnable" = "1" ]; then
Active5="$WanLocalActiveDate $WanLocalActiveTime"
Active5="0 0"
#echo "$Active1 $Active2 $Active3 $Active4 $Active5"
/usr/sbin/watchdog 30 "$x_NTPServer" "$x_TimeZone" $Active1 $Active2 $Active3 $Active4 $Active5
/usr/sbin/watchdog
# if watchdog process is killed, then reboot the system
kill -15 1
