Jan 1 02:00:04 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
Jan 1 02:00:04 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 02:00:04 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 02:00:04 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 02:00:04 kernel: ipt_time loading
Jan 1 02:00:04 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 02:00:04 kernel: IPv6 v0.8 for NET4.0
Jan 1 02:00:04 kernel: IPv6 over IPv4 tunneling driver
Jan 1 02:00:04 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 02:00:04 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 02:00:04 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 02:00:04 kernel: FAT: bogus logical sector size 60672
Jan 1 02:00:04 kernel: NTFS: Unable to set blocksize 512.
Jan 1 02:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 02:00:04 kernel: Mounted devfs on /dev
Jan 1 02:00:04 kernel: Freeing unused kernel memory: 72k freed
Jan 1 02:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 02:00:04 kernel: .90.37.0
Jan 1 02:00:04 kernel: PCI: Enabling device 01:03.0 (0004 -> 0006)
Jan 1 02:00:04 dnsmasq[72]: started, version 2.22 cachesize 150
Jan 1 02:00:04 dnsmasq[72]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 24h
Jan 1 02:00:04 dnsmasq[72]: DHCP, /tmp/dnsmasq.log will be written every 8h
Jan 1 02:00:04 dnsmasq[72]: read /etc/hosts - 4 addresses
Jan 1 02:00:04 dnsmasq[72]: reading /tmp/resolv.conf
Jan 1 02:00:04 kernel: eth1: Broadcom BCM4320 802.11 Wireless Controller 3.90.37.0
Jan 1 02:00:04 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 02:00:04 kernel: vlan0: add 33:33:ff:77:d5:84 mcast address to master interface
Jan 1 02:00:04 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 02:00:04 kernel: device eth0 entered promiscuous mode
Jan 1 02:00:04 kernel: device vlan0 entered promiscuous mode
Jan 1 02:00:04 kernel: device eth1 entered promiscuous mode
Jan 1 02:00:04 kernel: br0: port 2(eth1) entering listening state
Jan 1 02:00:04 kernel: br0: port 1(vlan0) entering listening state
Jan 1 02:00:04 kernel: br0: port 2(eth1) entering learning state
Jan 1 02:00:04 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 02:00:04 kernel: br0: topology change detected, propagating
Jan 1 02:00:04 kernel: br0: port 1(vlan0) entering learning state
Jan 1 02:00:04 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 02:00:04 kernel: usb.c: registered new driver usbdevfs
Jan 1 02:00:04 kernel: usb.c: registered new driver hub
Jan 1 02:00:05 kernel: usb-uhci.c: $Revision: 1.275 $ time 00:43:25 May 25 2006
Jan 1 02:00:05 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 02:00:05 kernel: PCI: Enabling device 01:02.0 (0000 -> 0001)
Jan 1 02:00:05 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
Jan 1 02:00:05 kernel: usb-uhci.c: Detected 2 ports
Jan 1 02:00:05 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 02:00:05 kernel: hub.c: USB hub found
Jan 1 02:00:05 kernel: hub.c: 2 ports detected
Jan 1 02:00:05 kernel: PCI: Enabling device 01:02.1 (0000 -> 0001)
Jan 1 02:00:05 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
Jan 1 02:00:05 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 02:00:05 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 02:00:05 kernel: PCI: Enabling device 01:02.2 (0000 -> 0002)
Jan 1 02:00:05 kernel: ehci_hcd 01:02.2: PCI device 1106:3104
Jan 1 02:00:05 kernel: ehci_hcd 01:02.2: irq 2, pci mem c00a7000
Jan 1 02:00:05 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 02:00:05 kernel: PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 02:00:05 kernel: ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 02:00:05 kernel: hub.c: 4 ports detected
Jan 1 02:00:05 kernel: usb.c: registered new driver usblp
Jan 1 02:00:05 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 02:00:07 kernel: usb.c: registered new driver audio
Jan 1 02:00:07 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 02:00:07 kernel: Linux video capture interface: v1.00
Jan 1 02:00:07 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 02:00:08 kernel: Initializing USB Mass Storage driver...
Jan 1 02:00:08 kernel: usb.c: registered new driver usb-storage
Jan 1 02:00:08 kernel: USB Mass Storage support registered.
Jan 1 02:00:08 kernel: vlan1: Setting MAC address to 00 15 f2 77 d5 84.
Jan 1 02:00:08 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 02:00:08 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 02:00:08 kernel: vlan1: add 33:33:ff:77:d5:84 mcast address to master interface
Jan 1 02:00:08 udhcpc[98]: udhcpc (v0.9.9-pre) started
Jan 1 02:00:08 kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
Jan 1 02:00:09 dnsmasq[72]: read /etc/hosts - 4 addresses
Jan 1 02:00:09 dnsmasq[72]: reading /tmp/resolv.conf
Jan 1 02:00:09 dhcp client: deconfig: lease is lost
Jan 1 02:00:09 udhcpc[98]: Lease of 192.168.2.103 obtained, lease time 18000
Jan 1 02:00:09 dnsmasq[72]: using nameserver 192.168.2.1#53
Jan 1 02:00:10 dhcp client: bound IP : 192.168.2.103 from 192.168.2.1
Jan 1 02:00:26 kernel: hub.c: new USB device 01:02.2-2, assigned address 2
Jan 1 02:00:26 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Aug 5 11:36:39 ntp client: Synchronizing time with time.nist.gov ...
Aug 5 11:36:39 kernel: Vendor: ST332062 Model: 0A Rev: 0 0
Aug 5 11:36:39 kernel: Type: Direct-Access ANSI SCSI revision: 02
Aug 5 11:36:39 kernel: Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Aug 5 11:36:39 kernel: SCSI device sda: 625142448 512-byte hdwr sectors (320073 MB)
Aug 5 11:36:39 kernel: Partition check:
Aug 5 11:36:39 kernel: p1
Aug 5 11:36:40 dnsmasq[72]: DHCPDISCOVER(br0) 00:13:ce:42:7d:1c
Aug 5 11:36:40 dnsmasq[72]: DHCPOFFER(br0) 192.168.1.208 00:13:ce:42:7d:1c
Aug 5 11:36:40 dnsmasq[72]: DHCPREQUEST(br0) 192.168.1.208 00:13:ce:42:7d:1c
Aug 5 11:36:40 dnsmasq[72]: DHCPACK(br0) 192.168.1.208 00:13:ce:42:7d:1c Dell
Aug 5 11:36:49 kernel: VFS: Can't find ext3 filesystem on dev sd(8,1).
Aug 5 11:36:49 kernel: MSDOS FS: Using codepage 950
Aug 5 11:36:49 kernel: MSDOS FS: IO charset cp950
Aug 5 11:36:49 USB storage: vfat fs mounted to /tmp/harddisk
Aug 5 11:36:49 FTP server: daemon is started
Aug 5 11:37:09 dnsmasq[72]: DHCPREQUEST(br0) 192.168.1.208 00:13:ce:42:7d:1c
