Code:ipkg install libncurses
hi,
i've installed firmware WLHDD-1.9.2.7-7e.trx and ipkg on my wl-hdd. i'm using macsat's ipkg package system Tutorial (http://www.macsat.com/macsat/content/view/22/29/).
All goes well until here:
Open the post-boot file in the nano editor:
/opt/bin/nano /usr/local/sbin/post-boot < enter >
I get the following error: /opt/bin/nano: can't load library 'libncurses.so.5'
What have I done wrong?
FYI:
Disk /dev/ide/host0/bus0/target0/lun0/disc: 60.0 GB, 60060155904 bytes
255 heads, 63 sectors/track, 7301 cylinders
Device Boot Start End Blocks Id S ystem
/dev/ide/host0/bus0/target0/lun0/part1 1 7260 58315918+ 83 Linux
/dev/ide/host0/bus0/target0/lun0/part2 7261 7301 329332+ 82 Linux swap
i can't find a package called that way
ncurses looks okayCode:[admin@(none) root]$ ipkg install libncurses Nothing to be done An error ocurred, return value: 4. Collected errors: Cannot find package libncurses. Check the spelling or perhaps run 'ipkg update'
anyone? is there a good alternative editor that i can install using ipkg?Code:[admin@(none) root]$ ipkg install ncurses Package ncurses (5.5-1) installed in root is up to date. Nothing to be done Successfully terminated.
resolved ..............
how did you resolve that problem?
Zigster
me too...
need help
Hello aflo,
please write how did you solve this problem. I have the same problem and I need help.
Thanks,
with best regards
Julian
