I didn't test it, but the latest ASUS FW (1.9.2.9) says some problems with it were fixed. I should work ok.
I need a router with a working bandwith management for down AND upload so I could reserve (approx. 100 kbit for each direction) bandwith for a VoIP client with it.
I remember to read in this forum, that the bandwith management for upload doesn't work properly for WL-500g and WL-500g Deluxe.
Does it probably work with WL-500 Premium? Original ASUS FW, or Olegs FW?
Thanks a lot!
BR
Robert
ISP: TV Cable 50/5 Mbit
thank you for the answer! Where can I have a look on the release note of this FW. Could you give me a link?
BR
Robert
http://support.asus.com/download/dow...Language=en-us
Release note on 1.9.2.9:
WL-500gP English/Traditional Chinese Firmware Version , version 1.9.6.9
Fixed bug:
* Fixed Bandwidth management issue
* Fixed samba server with NTFS issue
* Reduce WDS client to 2. User only can set 2 clients in WDS/Hybird mode
Add and Update
* Add new warning message in ftp user number
* Modify some rules about burning MAC/regulation_domain for factory
BR,
Martin
Well, i tested the Asus Premium with the Asus build in Bandwidth Management and i can say:
It doesnt work, if you want to control your WAN port
regards,
VampB
Hi VampB,
of couse I want to manage and to share my WAN bandwidth. VoIP works simply over WAN, how else?
Could you make your statement more precise? What dows work, what doesn't work, how does it show itself? Does it work with an alternate firmware (Oleg's, open WRT or something else)?
BR
Robert
