Results 1 to 4 of 4
Thread: How to mount an IP-drive?
    OK, these are the instruments: ASUS WL-500g and a Fan-tec NAS-drive attached to the WL-500g with assigned IP-address and samba enabled, two hands and intermediate level brains.
    My question: is it possible to mount the FAT32 partition/samba share on the WL-500g? (no USB connection, only ethernet). I have already tried the mount command, only to get the error "no such device".
    Is the WL-500g able to "scan" the samba shares within the network?
    JaDi.
    In case you would like to know why? I would like to install twonkyvision upnp server on the WL500g to be able to stream the content of this harddisk (500Gigs!) I was able to buy at a low price.
    Feb 2005
    Germany - Frankfurt a.M.
    hello,
    these so called IP-Drives has an own Sambaserver.
    So you dont have to mount it.
    You just have to enter the ip for the config page.
    It seems I haven't been clear enough. Connecting to the NAS-drive by typing the IP-address using another PC is no problem. I really would like to mount the contents of the HDD on the WL-500g filesystem, so that mediaserver software installed on the WL-500g can access the files on the harddisk via ethernet (instead of the much used method of connecting an extrernal HDD via USB).
    I have to mount the HDD filesystem because the mediaserver software is not able to access files by means of an IP-address.
    JaDi.
    Jun 2005
    Karlsruhe, Germany
    Lightbulb
    Please search for "smbmount"
    Last Post: 14-03-2012, 16:28
  2. Howto mount a CD-ROM drive into WL-500gx
    By Scoundrel in forum WL-500g Q&A
    Last Post: 19-07-2006, 21:56
  3. Mount problem (strenge)
    By qczek in forum WL-500g Custom Development
    Last Post: 01-02-2006, 14:05
