Hi all!
This tutorial is great. I got it all working. Except... trying to have 2 USB Printers.
My router is WL-500W. It has 2 USB Ports. The first one is connected to a USB Hard Disk directly. The other one is connected to a USB Hub. The 2 printers are then connected to the USB Hub.
It appears the problem is to do with the Printer Drivers. This is what it shows when i type "dmesg" in Putty.
[admin@hwei root]$ dmesg
instruction cache 16kb, linesize 16 bytes (2 ways)
Primary data cache 16kb, linesize 16 bytes (2 ways)
Linux version 2.4.20 (root@localhost) (gcc version 3.2.3 with Broadcom modifications) #9 Sun Oct 28 11:52:04 MSK 2007
Setting the PFC to its default value
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
CPU: BCM4704 rev 9 pkg 0 at 264 MHz
Calibrating delay loop... 263.78 BogoMIPS
Memory: 30012k/32768k available (1833k kernel code, 2756k reserved, 248k data, 72k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
PCI: Initializing host
PCI: Fixing up bus 0
PCI: Fixing up bridge
PCI: Fixing up bus 1
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
NTFS driver v1.1.22 [Flags: R/O]
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0xb8000300 (irq = 3) is a 16550A
ttyS01 at 0xb8000400 (irq = 3) is a 16550A
HDLC line discipline: version $Revision$, maxframe=4096
N_HDLC line discipline registered.
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
Amd/Fujitsu Extended Query Table v1.3 at 0x0040
Flash Id: Vendor: 0x0001 Device: 0x007e
number of CFI chips: 1
Flash device: 0x800000 at 0x1c000000
Physically mapped flash: squashfs filesystem found at block 953
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "boot"
0x00040000-0x007f0000 : "linux"
0x000ee744-0x007f0000 : "rootfs"
0x007f0000-0x00800000 : "nvram"
0x003e0000-0x007f0000 : "flashfs"
sflash: found no supported devices
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
Linux IP multicast router 0.06 plus PIM-SM
ip_conntrack version 2.1 (256 buckets, 2048 max) - 352 bytes per conntrack
ip_conntrack_pptp version 1.9 loaded
ip_nat_pptp version 1.5 loaded
ip_tables: (C) 2000-2002 Netfilter core team
ipt_time loading
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
IPv6 v0.8 for NET4.0
IPv6 over IPv4 tunneling driver
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
FAT: bogus logical sector size 22016
NTFS: Unable to set blocksize 512.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 72k freed
Algorithmics/MIPS FPU Emulator v1.5
eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.108.9.0
eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 4.108.9.0
PCI: Enabling device 01:02.0 (0004 -> 0006)
eth2: Broadcom BCM4329 802.11 Wireless Controller 4.108.9.0
device eth0 entered promiscuous mode
device eth2 entered promiscuous mode
br0: port 2(eth2) entering listening state
br0: port 1(eth0) entering listening state
br0: port 2(eth2) entering learning state
br0: port 1(eth0) entering learning state
br0: port 2(eth2) entering forwarding state
br0: topology change detected, propagating
br0: port 1(eth0) entering forwarding state
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-uhci.c: $Revision: 1.275 $ time 22:59:22 Oct 15 2007
usb-uhci.c: High bandwidth mode enabled
PCI: Enabling device 01:03.0 (0000 -> 0001)
ECHI PCI device 30381106 found.
UCHI reg 0x41 = 10
UCHI reg 0x41 changed to = 0
usb-uhci.c: USB UHCI at I/O 0x100, IRQ 12
usb-uhci.c: Detected 2 ports
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
PCI: Enabling device 01:03.1 (0000 -> 0001)
UCHI reg 0x41 = 10
usb-uhci.c: USB UHCI at I/O 0x120, IRQ 12
usb.c: new USB bus registered, assigned bus number 2
usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
PCI: Enabling device 01:03.2 (0000 -> 0002)
ehci_hcd 01:03.2: PCI device 1106:3104
ehci_hcd 01:03.2: irq 12, pci mem c00f1000
usb.c: new USB bus registered, assigned bus number 3
ECHI PCI device 31041106 found.
ECHI reg 0x49 = 80010f20
ECHI reg 0x49 changed to = 80010f00
ECHI reg 0x4b = 80010f09
ECHI reg 0x4b changed to = 80010f29
PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
hub.c: 4 ports detected
usb.c: registered new driver usblp
printer.c: v0.13: USB Printer Device Class driver
Linux video capture interface: v1.00
hub.c: connect-debounce failed, port 1 disabled
hub.c: new USB device 01:03.2-1, assigned address 2
usb.c: USB device 2 (vend/prod 0xd49/0x3200) is not claimed by any active driver.
SCSI subsystem driver Revision: 1.00
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: Maxtor Model: 3200 Rev: 0344
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
SCSI device sda: 312581808 512-byte hdwr sectors (160042 MB)
Partition check:
/dev/scsi/host0/bus0/target0/lun0: p1 p2 p3
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 2
USB Mass Storage support registered.
kjournald starting. Commit interval 5 seconds
EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,2), internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Adding Swap: 506008k swap-space (priority -1)
VFS: Can't find ext3 filesystem on dev sd(8,0).
MSDOS FS: Using codepage 950
MSDOS FS: IO charset cp950
FAT: bogus logical sector size 22278
VFS: Can't find a valid FAT filesystem on dev 08:00.
FAT: freeing iocharset=cp950
VFS: Can't find ext3 filesystem on dev sd(8,1).
FAT: bogus logical sector size 63222
VFS: Can't find a valid FAT filesystem on dev 08:01.
EXT3 FS 2.4-0.9.19, 19 August 2002 on sd(8,3), internal journal
The part that i made BOLD is why i think its a driver problem. And,.. only 1 printer is detected? correct? But I have 2 printers connected.
Please help.
