Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 123
Thread: [HowTo] Part One - WL-500g Premium
    Nov 2006
    Poland
    First you have to mount a harddisk/pendrive's partition to /opt. Check it with 'df' command.
    Powered by 2 Asus wl500g Premium :-)
    Jan 2007
    Romania
    Question Stupid-ftp problem
    Hello everybody!
    I've read the two tutorials, and managed to get samba and almost all the other stuff working except stupid-ftp.
    I've tried to find the config file necessary to run stupid-ftp (stupid-ftp.conf) but I can't find it anywhere.
    I have enabled FTP sever on the web interface, but still nothing. What can I do in such a case... when should this stupid-ftp.conf be created, and by who?
    If nobody can tell me, at least could someone please copy/paste a config file, so I could at least see how do they look like.
    Thanks guys!
    Regards,
    X
    thanks for the help gorion, i got the hard drive set up and all the apps installed correctly but for some reason i cant get samba to work,
    also i have to type post-boot after a restart, it doesnt do it automatically
    after i do run post-boot ctorrent starts, but when i click links like source and work, they dont go anywhere 404 error,
    also i cant get into my samba shares
    any ideas?
    most people have been saying set hostname, i do have it set in the web gui and a post-boot line as MyAsus,
    TIA
    Quote Originally Posted by africamagical View Post
    any ideas?
    TIA
    I have the same problems with post-boot! have you tried looking in 'ls -all' to see if its in there? (mine isnt btw) i cant seem to get it running... even with the chmod +x... ARGH!
    error message when installing screen
    I was following the instructions in the HOWTO, and it was fine until I got to installing screen, at which point it complained:
    [admin@(none) /opt]$ ipkg install screen
    Installing screen (4.0.3-2) to root...
    Downloading http://ipkg.nslu2-linux.org/feeds/un...3-2_mipsel.ipk
    Installing termcap (1.3.1-2) to root...
    Downloading http://ipkg.nslu2-linux.org/feeds/un...1-2_mipsel.ipk
    Configuring screen
    chown: unknown user name: root
    Configuring termcap
    Successfully terminated.
    It looks like it tried to chown something to user 'root', but the only user I have is 'admin'.
    I uninstalled screen:
    [root@(none) root]$ ipkg remove screen
    Removing package screen from root...
    Then used the web interface to change the user's name to root using System Setup > Change Name, then tried installing screen again and it worked that time.
    So should the HOWTO be changed to tell people to change the username to 'root' instead of 'admin', if that's what the packages expect to find? Or did I do the wrong thing?
    dropbear
    I'm kinda new to this router linux world, but I've decided to take out the parts I need from the guide.
    and start with dropbear, cuz ssh would be nice to use when out in the world
    when I have folowed the instruction, made the key, and the script.
    the thing is, that I can't just start dropbear.. nothing happens (I expect something to happen, since you made the remark with playing with it)
    Anything I need to do before this guide (use 1.9.7.2.f7)
    Quote Originally Posted by KingGuru View Post
    Do a ps and if dropbear is running then thats it.
    Then use e.g. putty from a PC to ssh into it.
    The first time you connect putty should ask you if you want to save the key from the ssh server (dropbear) on your Asus.
    Got it.. apperently I forgot to save
    but anyway.. I have trouble with the transmission for torrent. I get a file not found when I try to access the page /cgi-bin/trans....
    I have installet it with the ipkg system..
    I'am a newbie with Linux. (Yes anotherone...)
    I use the following firmware from Oleg: WL500gp-1.9.2.7-7f.trx
    During this manual i have 3 errors.
    ipkg install mc cannot find package mc
    ipkg install ctorrent ERROR: cannot satisfy the following dependencies
    for ctorrent: libstdc++
    ipkg install nload ERROR: cannot satisfy the following dependencies
    for nload: libstdc++
    Can anyone help me?
    MMhhmmm....
    Some things aren't as difficult as they seem.
    I did -ipkg install libstdc++- and now ctorrent and nload installed correctly.
    Leaves one question: How to get MC?
    My experiences
    I had the same problems as most people here
    When you make your partionstions make 2 primary partiotions, do not make any extrended ones. MC wont install since it has been removed from the repository, just skip it unless you know what you are doing. As pinkpanter said, you have to install libstdc++ before you try to install ctorrent.
    Instead of putting
    /usr/sbin/busybox_httpd -p 8008 -h /opt/share/www
    in post-mount, put it in post-firewall and you should be fine!
    Regards to the samba problem the solutions has already been described,
    if your content of /opt/etc/init.d/S97Samba is:
    #!/bin/sh /usr/sbin/smbd -D -l /opt/var/log/smbd.log -s /opt/etc/samba/smb.conf /usr/sbin/nmbd -D -n myasus -o -l /tmp -s /opt/etc/samba/smb.conf
    then you should set you hostname in the webinterface (IP config / WAN & LAN / Hostname) to myasus
    From what I can tell samba and bittorrent works much better now then with the original asus firmware, many thanks to oleg and to marcnesium!!
    Nov 2006
    Lisbon@Portugal
    Update for Oleg 1.9.2.7-7f with Samba2 and Transmission
    This guide is written supposing that your PC runs Windows, and you want to use your router as file server and Torrent client. My objective was to setup Oleg 1.9.2.7-7f with Transmission and Samba2.
    Step 1 - Install required HW and SW
    1) Connect your PC to the wl-500gP using an ethernet cable (you should not use wireless during Step 1), and make sure that you can connect to the Ethernet
    2) Download and install putty and ASUS fw restoration utility
    3) Download Oleg 1.9.2.7-7f firmware
    4) Unplug all USB devices from the router, and disconnect the modem cable
    5) Using the web interface, reset the router to factory settings
    6) Put the router in restoration mode
    7) Start ASUS firmware restoration utility and load Oleg fw into the router. Do not interrupt this step, the router may have to be repaired or replaced if you interrupt the load. The router will reboot automatically
    8) Connect modem to router, and parametrize it using web interface (at this stage userid/password is admin/admin). Here are some of my parameters:
    - Maintain 192.168.1.1 as the router's IP address, and limit DHCP to 192.168.1.2/24
    - Activate Telnet and DDNS
    - Deactivate ftp and samba
    - Allow ping from WAN side
    - If you use wireless, select 32mW as the transmission power and activate the maximum possible security supported by your PC's (in my case WEP128 + mac access + hide SSID)
    - In LAN IP Setting / Host name specify a hostname of your choice (mine is MyASUS)
    9) Reboot the router (using web interface)
    You may have to calibrate the wireless part (it took me about 2 weeks to reach an acceptable setup). You can use NetStumbler to help you.
    Step 2 - Prepare disk
    1) Connect disk to router
    2) Start putty in Windows (all the remaining actions should be performed in line mode, not web interface). Point it to 192.168.1.1, telnet, keyboard with Linux function keys. You can save 3 profiles in putty, one for Telnet (from LAN), and two for SSH (from LAN and WAN). Paste lines in putty with right click on mouse.
    3) Format the disk with 3 primary partitions, first with +512M for swap (select type 82), second with +1G (for /opt), and 3rd with the rest. Use fdisk help to guide you.
    insmod scsi_mod && insmod sd_mod && insmod usb-storage && sleep 5s
    fdisk /dev/discs/disc0/disc
    4) Reboot
    reboot
    5) Format and mount the disk
    mkswap /dev/discs/disc0/part1
    swapon /dev/discs/disc0/part1
    mke2fs -j /dev/discs/disc0/part2
    mount /dev/discs/disc0/part2 /opt
    mke2fs -j /dev/discs/disc0/part3
    6) Install base packages (ignore errors regarding wl500g):
    cd /opt/
    mkdir /opt/tmp
    mkdir /opt/tmp/ipkg
    wget http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/ipkg-opt_0.99.163-9_mipsel.ipk
    ipkg.sh install ipkg-opt_0.99.163-9_mipsel.ipk
    wget http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/uclibc-opt_0.9.28-12_mipsel.ipk
    ipkg.sh install uclibc-opt_0.9.28-12_mipsel.ipk
    ipkg update
    ipkg install nano
    rm *.ipk
    7) Create startup scripts and install dropbear
    mkdir -p /usr/local/etc/dropbear
    dropbearkey -t dss -f /usr/local/etc/dropbear/dropbear_dss_host_key
    dropbearkey -t rsa -f /usr/local/etc/dropbear/dropbear_rsa_host_key
    mkdir -p /usr/local/sbin
    nano /usr/local/sbin/post-boot
    Here is my post-boot file:
    # Start SSH service
    dropbear
    # test if USB disc has been attached
    # if not - then insert needed modules
    if [ ! -d /dev/discs ]
        then
    # Wait for /opt to mount
    mount /dev/discs/disc0/part3 /tmp/harddisk
        i=0
    while [ $i -le 30 ]
        do
    if [ -d /opt/etc ]
        then
        break
    sleep 1
    i=`expr $i + 1`
        done
    # Activate swap
    #to let midnight commander run on terminals, make alias for colored mc
    echo "export TERMINFO=/opt/share/terminfo">>/etc/profile
    echo "alias mc=\"mc -c\"">>/etc/profile
    # Run all active services - active means starts with S
    /opt/etc/init.d/rc.unslung
    Next let's create the post-firewall file
    nano /usr/local/sbin/post-firewall
    Here is my post-firewall
    ## FIREWALL
    ## set default policy
    iptables -P INPUT DROP
    ## deny ftp access from WAN
    iptables -I INPUT 1 -p tcp -i "$1" --syn --dport 21 -j DROP
    ## Allow access to various router services from WAN
    ## Ports 22 and 65534 are required by dropbear and transmission
    for P in 65534 22; do
      iptables -I INPUT 1 -p tcp --syn -i "$1" --dport $P -j ACCEPT
    done
    Create remaining files:
    touch /usr/local/sbin/post-mount
    touch /usr/local/sbin/pre-shutdown
    chmod +x /usr/local/sbin/*
    8) Save to flash and reboot
    At the end of this Step2 the router should be able to boot, mount the disk, and use the swap. You can verify this with
    mount
    free
    This should produce an output similar to
    [xxxx@MyASUS root]$ mount
    none on /dev type devfs (rw)
    proc on /proc type proc (rw)
    ramfs on /tmp type ramfs (rw)
    /dev/discs/disc0/part2 on /opt type ext3 (rw)
    /dev/discs/disc0/part3 on /tmp/harddisk type ext3 (rw)
    [xxxx@MyASUS root]$ free
                  total         used         free       shared      buffers
      Mem:        30140        13744        16396            0         4148
     Swap:       500712            0       500712
    Total:       530852        13744       517108
    Step3 - Install samba2
    Samba2 comes with a web interface from where you can parametrize and restart the service without rebooting the router.
    ipkg install mc
    ipkg install xinetd
    ipkg install samba2
    Create folder for samba shares
    mkdir /tmp/harddisk/share
    chmod ugoa+w /tmp/harddisk/share
    Create rc.unslung (to start all your services automatically after each reboot)
    nano /opt/etc/init.d/rc.unslung
    Here is my rc.unslung file:
    # Start all init scripts in /opt/etc/init.d
    # executing them in numerical order.
    for i in /opt/etc/init.d/S??* ;do
        # Ignore dangling symlinks (if any).
        [ ! -f "$i" ] && continue
        case "$i" in
           *.sh)
               # Source shell script for speed.
                   trap - INT QUIT TSTP
                   set start
                   . $i
               # No sh extension, so fork subprocess.
               $i start
       esac
    done
    Edit /opt/etc/xinetd.d/swat file (with nano or mc) to update the "user = root" line with your userid (such as "user = admin").
    Make rc.unslung executable, and execute it to start xinetd and samba2
    chmod +x /opt/etc/init.d/rc.unslung
    Open your browser to http://192.168.1.1:901 and parametrize samba at your will. I have removed all shares and created two new ones:
    - Share (pointing to /tmp/harddisk/share)
    - Torrent (pointing to /tmp/harddisk/torrent)
    Step4 - Install Tranmission
    This was my choice for torrent client. It's easy to use. You can either store .torrent files in //myasus/torrent/source or use Transmission's fetch button. At the moment transmission is going through changes, so what follows may not apply in the near future.
    ipkg install cron
    ipkg install gnuplot
    ipkg install logrotate
    ipkg install transmission
    Create torrent directories
    cd /tmp/harddisk
    mkdir torrent
    mkdir torrent/source
    mkdir torrent/target
    mkdir torrent/work
    chmod ugoa+w torrent
    chmod ugoa+w torrent/source
    chmod ugoa+w torrent/target
    If your administration userid has been renamed from admin to something else, use mc to replace admin in /opt/etc/transmission.conf and /opt/share/www/cgi-bin/transmission.cgi.
    Using mc, edit /opt/etc/transmission.conf to update TIMEZONE.
    Edit opt/etc/crontab file. Mine is (replace xxxx with your admin userid):
    SHELL=/bin/sh
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/opt/sbin:/opt/usr/bin:/opt/usr/sbin
    MAILTO=""
    HOME=/
    # ---------- ---------- Default is Empty ---------- ---------- #
    */30 * * * * xxxx nice /opt/sbin/transmission_watchdog
    0 0 * * * xxxx /opt/sbin/logrotate -f /opt/etc/logrotate.conf &>/dev/null
    Create S05syslogd, this is necessary to replace logging on memory by logging on disk, and make it available for gnuplot.
    nano /opt/etc/init.d/S05syslogd
    Here is mine:
    # Startup script for syslogd
    # Stop myself if running
    if [ -n "`pidof syslogd`" ]; then
    killall syslogd 2>/dev/null
    /sbin/syslogd -m 0 -O /opt/var/log/messages -S -l 7
    Make it executable:
    chmod +x /opt/etc/init.d/S05syslogd
    Go to web interface, deactivate telnet and reboot. After that, you can access Transmission from Windows pointing your browser to http://192.168.1.1:8008/cgi-bin/transmission.cgi
    Next Steps (optional)
    1) Here are some suggestions
    2) Activate ftp in web interface (to share /tmp/harddisk)
    Last edited by Moody Blue; 01-04-2007 at 14:42. Reason: Updated to include dropbear and ftp
    Same problem over here!
    im doing fine untill the ipkg setup,
    when i type:
    mkdir /opt/tmp
    I get the following error:
    mkdir: cannot create directory '/opt/tmp' :Read-only file system
    any help is appreciated, i neeeed to get the ctorrent working as the asus download manager blows
    Unhappy Web interface for SAMBA 2 not active ...
    Hi there ...
    Thanks a lot for the excellent tutorials ... for a linux beginner as me is this perfect.
    I followed MoodyBlue's tutorial but can not get SAMBA working.
    I can not connect to 192.168.1.1:901 for the web interface. The router webinterface 192.168.1.1 is working and accessible.
    The services are started and running, did not get any error messages.
    Does any one know how to solve this.
    Thanks in advance!
    Feb 2005
    Germany - Frankfurt
    Try "netstat -ln"
    Is there something listening on port 901?
    Using "ps axf":
    Is xinetd running?
    Is swat running?
  1. Asus WL-500g Premium и шлюз
    By Grig_oriy in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 15-05-2012, 21:43
  2. Установка svn на Asus WL-500g Premium
    By aka_mev in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 19-03-2012, 21:01
  3. Сборка пакетов под WL-500g Premium
    Last Post: 24-11-2011, 13:28
  4. WL-500g Premium died After Upgrading Firmware
    By acidbrain in forum WL-500gP Firmware Discussion
    Last Post: 17-06-2011, 08:59
  5. HOWTO use your WL-500g as IPv6 router
    By phedny in forum WL-500g/WL-500gx Tutorials
    Last Post: 17-02-2008, 08:19
