Look here:
http://oleg.wl500g.info/gp.old/
Oleg moved betas for EXPERIMENTAL peoples.
Oleg, when will up on your site the checked firmware for 500gp?
Till then, someone have a link to latest Oleg's firmware?
i would like to test it.
Look here:
Thank you nik
Hi Oleg and guys
I've juste purchased a Wl500gP to replace my Deluxe box.
If I understand correctly I sould stay on Asus firmware and wait Oleg issue a new one ?
Or If I'd like to take risks I could play with the experimental ones
Yeah, that was exactly the correct descripton!
I tried to flash the router with my self build firmware, but it failed. Before grounding pin 9 my LED was already flashing slowly (but the router was not reachable on its last IP 192.168.1.1), after grounding, it stopped flashing and after power cycling with restore button it flashed again slowly, but was reachable again on 192.168.1.1. My old settings were still there!
After trying to ground pin 9 several times, I succeeded. Here are some additional tips:
* take ground signal from UART (is not so tiny)
* take two metal screw drivers and cross them
* take a (wireless) switch for power
* use the switch with toe (this way you need no third hand or to jig)
Best regards
Thorsten
Hallo,
is there anything new with oleg firmware? long time ago there was beta, nothing new.
(Just polite question, I know Oleg is "only" human and his fw are not commercial)
thanks.
Miko,
(user of WL500gx, WL167, WL108 and now unhappy from wireless range of WL500gP and no OLEG fw)
Latest beta is -pre8: http://oleg.wl500g.info/gp/WL500gp-1.9.2.7-7f-pre8.trx
is there also a latest non beta?
or is it still pre4?
and has the latest Beta's been tested on routers without the pin9 trick?
thank you
Techwarrior (web-based game, good to work ) http://world2.techwarrior.co.uk/?ac=vid&vid=45074554
Hello...
after i tryed the pin 9 trick my 500gp was alive again, but i can not change the ram to 32MB...
i brik it when i overclock it to 300MHz, and the only solution was the pin mode trick, i even tryed to overclock it again to 280MHz (worked before pin 9) and it does not accept it... so after pin 9 trick i can not overclock it or expand the memory to 32MB...
any ideas?
Thanks in advance...
Asther.
hello , yesterday i bricked my ASUS and went to a friend whitch
had a PC to try the "restoration tool" but it can´t find a device
and the "upload " new firmaware proggi say :" invalid ip adress" so he is flashing a random ipdrassinto NVRAM
and when DHCP server is not working , you have no possibility to get the right ip adress , i am right ?
Sombody told me that i have to configure a static ip adress and subnet on the PC before i do this
what subnet i should use = 255.255.255.255 or 255.255.255.0 ?
so i am guessing the " pin 9 " method is the ONLY way ?
I figured out that some times after several resets the " power LED was flashing , what can i do ? So if i understand correctly when its in "restore mode" i could flash new firmware ? for how long do i need to connect the ground to "pin9" ?
thanks so much
I have a same problem and don't know to ground the pin. I'm not a eletronic guy. Anyone can describe the procedure?
