Results 1 to 6 of 6
Thread: Wl500gp external antenna and wireless no so fast.
    Hi. I am Russian. Maybe write in russian topic?
    So when i transfer through wifi speed not so good at 3 mbit/s. (Last firmware, standart G, notebook with all settings to max preformance in wifi driver, on friends notebook the same). It is normal?
    Another question it has external antenna. I try to take off antena and it works on the same speed, like with antenna. Maybe somewhere option to turn on external antenna?
    Coz i did not notice difference with external antenna is connected or disconnected.
    Jul 2006
    As far as I know the box has an internal antenna, too. So it will work without the external one.
    "Documentation is like sex. If it is good, it is REALLY good, and if it is bad, it is better than nothing!" Gabe Helou
    i've got 500gP and Dlink DWL-G510 PCI card...
    feel myself like with modem connection.
    2.2mb/s
  4. Red face internal antena
    Yes, there is internal antena. Its much more better than in WL-500g.
    external/internal antenna switching
    Hi, does anybody know a way to switch antennas?
    (if it's possible, on original asus firmware, if not, how about oleg's one)
    I like to use external, but don't know, which is set by default.
    The Netherlands - Eindhoven
    Quote Originally Posted by Agv View Post
    depending on the signal strengt and enviroment, the speed can be 3mb/s
    the wifi speed of the wl500gp is 54mbits, so
    54mbits/8= 6.75mb/s max under ideal circumstances.
    and even then, its theoretical.
    you will never be able to get that speed.
    so I would say, if you have around 3 to 4mb/s you have a good wireless connection, otherwise check if there are things you can do better, like switching channels, using usb-hubs with psu so the wireless can get more power etc.
    with the wl-500w I easily get above 10mb/s, it is just faster than the 100mbits wire connection
    in the end, wireless will always be a little devil
  1. Asus WL-700g Marketing Specifications
    By Antiloop in forum WL-700g Pics & Specs
    Last Post: 19-12-2006, 19:49
  2. help:Wl500g & Linksys 7db antenna
    By marciton in forum WL-500g Q&A
    Last Post: 04-02-2006, 17:38
  3. Signal Power
    By Panja in forum Dutch Discussion - Nederlands
    Last Post: 24-09-2005, 03:46
