Hi et all, especially Oleg,
first of all, thanks for this firmware, until now it works really fine! So: respect! But now I have a problem with my (ok, quiet old) Lexar 64MB USB-Stick. When I plug it in, the box seems to restart ca. every two minutes. I just managed to login and get a dmesg-log:
cpu probe
prom init
cpu report
CPU revision is: 00029006
Primary instruction cache 16kb, linesize 16 bytes (2 ways)
Primary data cache 16kb, linesize 16 bytes (2 ways)
Linux version 2.4.20 (root@omnibook) (gcc version 3.2.3 with Broadcom modifications) #46 Thu May 25 22:40:57 MSD 2006
Setting the PFC value as 0x15
Determined physical RAM map:
memory: 02000000 @ 00000000 (usable)
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc console=ttyS0,115200
CPU: BCM4704 rev 8 at 264 MHz
Calibrating delay loop... 263.78 BogoMIPS
Memory: 30068k/32768k available (1776k kernel code, 2700k reserved, 248k data, 72k init, 0k highmem)
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
PCI: Fixing up bus 0
PCI: Fixing up bridge
PCI: Fixing up bus 1
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Journalled Block Device driver loaded
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
NTFS driver v1.1.22 [Flags: R/O]
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0xb8000300 (irq = 3) is a 16550A
ttyS01 at 0xb8000400 (irq = 3) is a 16550A
HDLC line discipline: version $Revision$, maxframe=4096
N_HDLC line discipline registered.
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
Amd/Fujitsu Extended Query Table v1.3 at 0x0040
number of CFI chips: 1
Flash device: 0x800000 at 0x1c000000
Physically mapped flash: squashfs filesystem found at block 945
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "pmon"
0x00040000-0x003e0000 : "linux"
0x000ec55c-0x003e0000 : "rootfs"
0x007f0000-0x00800000 : "nvram"
0x003e0000-0x007f0000 : "config"
sflash: found no supported devices
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
ip_conntrack_pptp version 1.9 loaded
ip_nat_pptp version 1.5 loaded
ip_tables: (C) 2000-2002 Netfilter core team
ipt_time loading
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
IPv6 v0.8 for NET4.0
IPv6 over IPv4 tunneling driver
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
FAT: bogus logical sector size 36864
NTFS: Unable to set blocksize 512.
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 72k freed
Algorithmics/MIPS FPU Emulator v1.5
eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.37.0
unregister_netdevice: device eth1/81066800 never was registered
PCI: Enabling device 01:02.0 (0004 -> 0006)
eth1: Broadcom BCM4318 802.11 Wireless Controller 3.90.37.0
vlan0: add mcast address to master interface
vlan0: dev_set_promiscuity(master, 1)
device eth0 entered promiscuous mode
device vlan0 entered promiscuous mode
device eth1 entered promiscuous mode
br0: port 2(eth1) entering listening state
br0: port 1(vlan0) entering listening state
br0: port 2(eth1) entering learning state
br0: port 1(vlan0) entering learning state
br0: port 2(eth1) entering forwarding state
br0: topology change detected, propagating
br0: port 1(vlan0) entering forwarding state
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-uhci.c: $Revision: 1.275 $ time 10:25:12 Jun 17 2006
usb-uhci.c: High bandwidth mode enabled
PCI: Enabling device 01:03.0 (0000 -> 0001)
ECHI PCI device 30381106 found.
UCHI reg 0x41 = 10
UCHI reg 0x41 changed to = 0
usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
usb-uhci.c: Detected 2 ports
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 2 ports detected
PCI: Enabling device 01:03.1 (0000 -> 0001)
UCHI reg 0x41 = 10
usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
usb.c: new USB bus registered, assigned bus number 2
usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
PCI: Enabling device 01:03.2 (0000 -> 0002)
ehci_hcd 01:03.2: PCI device 1106:3104
ehci_hcd 01:03.2: irq 2, pci mem c00a7000
usb.c: new USB bus registered, assigned bus number 3
ECHI PCI device 31041106 found.
ECHI reg 0x49 = 80010f20
ECHI reg 0x49 changed to = 80010f00
ECHI reg 0x4b = 80010f09
ECHI reg 0x4b changed to = 80010f29
PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
hub.c: 4 ports detected
usb.c: registered new driver usblp
printer.c: v0.13: USB Printer Device Class driver
Linux video capture interface: v1.00
SCSI subsystem driver Revision: 1.00
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
vlan1: Setting MAC address to.
VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
vlan1: add mcast address to master interface
hub.c: new USB device 01:03.0-2, assigned address 2
scsi0 : SCSI emulation for USB Mass Storage devices
Vendor: LEXAR Model: JUMPDRIVE Rev: 1.01
Type: Direct-Access ANSI SCSI revision: 02
Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
SCSI device sda: 125952 512-byte hdwr sectors (64 MB)
sda: Write Protect is off
Partition check:
/dev/scsi/host0/bus0/target0/lun0: p1 p2 p3 p4
WARNING: USB Mass Storage data integrity not assured
USB Mass Storage device found at 2
So, perhaps somebody have the same problems and found already a solution. Thanks for every help!
Ciao Marc
