Also works on usb port (wl-500g deluxe)Originally Posted by Ark+
Tested: Working (but no bidirectional support)
Model: WL-500g Deluxe
Firmware: 1.9.2.7-7b (Oleg's)
Device:
Brandname: Canon
Brandtype: i550
USB Interface: 2.0
Notes:
- bidirectional support does not seem work (even with p910nd -b)
- Canon Status Monitor has to be disabled (= no ink level status)
- No Out of paper reporting back to printer driver
- Manual Duplex/Booklet printing not possible due to above
Tested: WORKING!
Model: WL-500g
Firmware: 1.9.2.7 (from ASUS website)/ tested with 1.6.5.3 but I didn't get it to work, could be due to lack of knowledge of myself
Device
Brandname: HP (Hewlett Packard)
Brandtype: Deskjet 656c
USB Interface: 1.1 compliant
URL To manufacturer: http://www.hp.com
URL To product:
Note: has some problems with RAW printing. Sometimes prints same pages multiple times and stops after he done 1 page than orange led is flashing. Press button to continue printing. Works fine with LPR printing method.
Note2: I advise to use te corporate drivers from the HP site. Otherwise you have to connect the printer to every PC in the network first. And you have to change the port where printer has to print to.
Model: WL-500g
Device:
Brandname: Canon
Brandtype: Pixma IP4200
USB Interface: 2.0
Notes:
- Duplex printing available
Tested: NOT WORKING!
Model: WL-500g
Firmware: 1.9.5.4
Device
Brandtype: PSC 1510
USB Interface: 2.0 compliant
If sbdy can make it working, please write me.
Tested: WORKING!
Model: WL500g
Device
Brandname: Epson
Brandtype: Stylus Photo 900
OS: WinXP Pro SP2
Interface: USB 2.0
Ports:
-- LPRServer, Bidirectional, Queue used
-- RAW 9100, No Bidirectional, No Queue
I think, some other configurations work too, but I not tested it...
URL To manufacturer: http://www.epson.com
URL To product: http://esupport.epson-europe.com/Pro...B36D9ECBE7E66A
P.S.
1) Epson Status Monitor not work (can't get ink and printer information)
2) If document not printing, but it show in print-queue, uncheck "Work Offline" option.
Tested: WORKING!
Device
Brandtype: Laserjet 1022
USB Interface: 2.0
Tested: WORKING!
Model: WL-500gx
Firmware: 1.9.5.0 / 1.9.2.7 6b Oleg
Device
Brandname: Samsung
Brandtype: ML-1610
USB Interface: 1.1
URL To manufacturer: http://www.samsung.com
URL To product: http://www.samsung.com/Products/Prin...ML_1610XAA.asp
Tested: Working
Device:
Brandname: Xerox
Brandtype: Phaser 3117
Tested: Working
Model: HP LaserJet 1022
Device:
Brandname: HP
Brandtype: LaserJet 1022
USB Interface: 2.0
Tested: WORKING!
Model: WL-500g
Firmware: Oleg 1.9.2.7
Device
Brandname: Epson
Brandtype: Stylus C64
USB Interface: 2.0
URL To product: http://www.epson.com/cgi-bin/Store/s...view&oid=23952
Tested: Working (printing only)
Model: WL-500g
Firmware: 1.9.2.7-7c Oleg's
Device:All in One Multifunction Printer
Brandname: HP
Brandtype: Officejet 5510
USB Interface: I guess it's 1.1 (can't find any info at hp.com)
Not too sure about the RAW setting, sometimes it works, sometimes not. The LPR setting seems more stable..
When installing the driver for this printer, try using the driver for HP Deskjet 3650 instead. It's an "Alternate print driver" for this product, listed here: http://tinyurl.com/on3zu ..If you use the intended driver, the printer must be connected to every PC first.
Tested: WORKING
Model: WL-500gx
Device
Brandname: Xerox
USB Interface: USB 1.1
URL To manufacturer: http://www.xerox.ru
URL To product: http://xerox.ru/themes/basic/product...6&FoundID=4083
Tested: WORKING! (bidirectional support not tested yet)
Model: WL-500gx
Firmware: Olegs 1.9.2.7-7c (Thank You!)
Device
Brandname: Epson
Brandtype: Stylus CX5400
USB Interface: 2.0
URL To product: not found on website
ested: WORKING! (bidirectional support not tested)
Model: WL-500gx
Device
Brandname: Brother
Brandtype: HL-2030
USB Interface: 2.0
URL To manufacturer: http://www.brother.com
URL To product: http://www.brother.com/europe/printe...l2030_fea.html
