Tested: NOT WORKING!
Model: WL-500g
Firmware: 1.6.5.3
Device
Brandname: HP (Hewlett Packard)
Brandtype: Laserjet 1000
USB Interface: YES
URL To manufacturer: HP.com
URL To product: HP LaserJet 1000
Tested: WORKING!
Model: WL-500g
Firmware: 1.7.5.6CR5
Device
Brandtype: Color Laserjet 1500L
USB Interface: HI-Speed USB (compatible with USB 2.0 specifications)
URL To manufacturer: http://www.hp.com
URL To product: http://h10010.www1.hp.com/wwpc/us/en...37-239138.html
Model: WL-500g
Firmware: 1.6.5.3
Device
USB Interface: YES
Model: WL-500g
Firmware: 1.7.5.6
Device
USB Interface: YES
URL To manufacturer: http://www.HP.com
Tested: WORKING!
Model: WL-500g
Firmware: 1.7.5.6-3 (Oleg's custom)
Device
Brandname: Brother
Brandtype: HL-1430
USB Interface: 2.0 compliant
URL To manufacturer: brother.
URL To product: http://solutions.brother.com/hl1430/index.html.
Note: The latest Mac OS X driver is PCL and works like a charm across the network. It works both with the latest ASUS firmware and the HP/JetDirect-printserver in Oleg's firmware (which seems to be faster!).
Tested: WORKING
Model: WL-500g
Firmware: 1.7.5.6-CR3
Device
Brandname: HP
Brandtype: Officejet V40
USB port: YES (only option)
You have to set RAW portnumber at 9101
Tested: WORKING
Model: WL-500g
Firmware: 1.7.5.9-5
Device
Brandname: Epson
Brandtype: C42UX
USB Interface: YES
URL To manufacturer: http://www.epson.com
Tested: WORKING
Model: WL-500g
Firmware: 1.7.5.9-4 [oleg]
Parallel Port: YES (working with RAW on 9100)Originally Posted by calimero
URL To manufacturer: http://www.canon.com
URL To product: http://www.canon.co.uk/For_Home/Prod...bble_Jet/i865/
on mac os X there is no proper driver for i865 for use with printservers (i.e. you cant use the osx driver delivered with the printer)
solution:
- CUPS driver from http://www.printfab.de (30day-trial)
- usb-plugged into apples airport express base station
- usb-plugged into canons wireless printserver
Tested: WORKING!
Model:WL-500g
Firmware: 1.8.1.9
Device
Brandname: Samsung
Brandtype: ML-1430
USB Interface: 1.1
URL To product: http://www.samsung.com
Not working on Parallel Port.
Tested: WORKING!
Model: WL-500g; WL-138G; WL-160G
Firmware: 1.6.5.3
OS; W98, W98SE; WXP Pro
works on LPT1 and USB
Device
Brandtype: Laserjet 3020 multifunction
USB Interface: 1.1 compliant
URL To product: http://h10010.www1.hp.com/wwpc/us/en...&lang=en&cc=us![]()
Tested: WORKING!
Model:WL-500g
Firmware: 1.7.5.9-5
Device
Brandname: HP
Brandtype: Officejet PSC 1350
USB Interface: 2.0
URL To product: http://www.hp.com
I am happynow. But don't forget to setup your printer for raw 9101 port communication.
Tested: working
Model: WL-500g
Firmware: 1.8.1.9
Device
Brandname: Samsung
Brandtype: ML1210
URL To manufacturer: http://www.samsung.com
URL To product: Click
Using Win XP SP2 I set the printer to use LPR mode (queue name LPRServer), I couldn't get raw mode to work. It's very slow compared to having the printer directly connected.
Note from admin: you can't use RAW printing because the stock asus firmware does not contain this (the changelog never said this also)
Tested: WORKING!
Model: WL-500g
Firmware: 1.8.1.9
Device
Brandtype: Laserjet 4050
Interface : Parallel interface
OS: WinXP SP2
I installed it by making an local TCP/IP port, with the LPR options.
Then installed printer on that port. And voila it worked!
Tested : WORKING
Model: WL-500g
Firmware: 1.8.1.9
Device
Brandname: EPSON
Brandtype: PHOTO R300
USB Interface: 2.0
URL To Manufacturer www.epson.com
Tested: WORKING
Model: WL-500g
Firmware: 1.7.5.9-5
Device
Brandname: EPSON
Brandtype: Photostylus Photo R200
URL To product: http://www.epson.co.uk/products/inkj...Photo_R200.htm
N.B. Wouldn't work with the RAW printing on port 9101, but works fine with the standard LPRServer printer queue.
Tested: WORKING
Model: WL-500g
Firmware: 1.8.1.9
Device
Brandtype: LaserJet 1010
Interface : USB
OS: WinXP SP2
You have to make an local TCP/IP port with the LPR options.
note from admin: this is in the manual..?
