I tryed a factory reset from the router's web interface.
Then I didn't modified anything just enabled flashfs, but it didn't work.
I still can't run the script when it starts with #!/bin/sh
(Now I see, the original "user name" was not root but admin.)
Anyway, I don't know why can I run an other script from /sbin (/sbin/wshaper)
And why can I run it from elsewhere (if I copy it to another directory):
# Wonder Shaper
DOWNLINK=$3
UPLINK=$4
DEV=$2
NOPRIOHOSTSRC="$5"
NOPRIOHOSTDST="$6"
NOPRIOPORTSRC="$7"
NOPRIOPORTDST="$8"
if [ "$1" = "status" ]
then
tc -s qdisc ls dev $DEV
tc -s class ls dev $DEV
exit
tc qdisc del dev $DEV root 2> /dev/null > /dev/null
tc qdisc del dev $DEV ingress 2> /dev/null > /dev/null
if [ "$1" = "stop" ]
then
exit
###### uplink
tc qdisc add dev $DEV root handle 1: htb default 20
tc class add dev $DEV parent 1: classid 1:1 htb rate ${UPLINK}kbit burst 6k
# high prio class 1:10:
tc class add dev $DEV parent 1:1 classid 1:10 htb rate ${UPLINK}kbit \
burst 6k prio 1
tc class add dev $DEV parent 1:1 classid 1:20 htb rate $((9*$UPLINK/10))kbit \
burst 6k prio 2
tc class add dev $DEV parent 1:1 classid 1:30 htb rate $((8*$UPLINK/10))kbit \
burst 6k prio 2
tc qdisc add dev $DEV parent 1:10 handle 10: sfq perturb 10
tc qdisc add dev $DEV parent 1:20 handle 20: sfq perturb 10
tc qdisc add dev $DEV parent 1:30 handle 30: sfq perturb 10
tc filter add dev $DEV parent 1:0 protocol ip prio 10 u32 \
match ip tos 0x10 0xff flowid 1:10
match ip protocol 1 0xff flowid 1:10
tc filter add dev $DEV parent 1: protocol ip prio 10 u32 \
match ip protocol 6 0xff \
match u8 0x05 0x0f at 0 \
match u16 0x0000 0xffc0 at 2 \
match u8 0x10 0xff at 33 \
flowid 1:10
for a in $NOPRIOPORTDST
do
tc filter add dev $DEV parent 1: protocol ip prio 14 u32 \
match ip dport $a 0xffff flowid 1:30
done
for a in $NOPRIOPORTSRC
do
tc filter add dev $DEV parent 1: protocol ip prio 15 u32 \
match ip sport $a 0xffff flowid 1:30
done
for a in $NOPRIOHOSTSRC
do
tc filter add dev $DEV parent 1: protocol ip prio 16 u32 \
match ip src $a flowid 1:30
done
for a in $NOPRIOHOSTDST
do
tc filter add dev $DEV parent 1: protocol ip prio 17 u32 \
match ip dst $a flowid 1:30
done
# rest is 'non-interactive' ie 'bulk' and ends up in 1:20
tc filter add dev $DEV parent 1: protocol ip prio 18 u32 \
match ip dst 0.0.0.0/0 flowid 1:20
########## downlink #############
tc qdisc add dev $DEV handle ffff: ingress
tc filter add dev $DEV parent ffff: protocol ip prio 50 u32 match ip src \
0.0.0.0/0 police rate ${DOWNLINK}kbit burst 10k drop flowid :1
And I don't know why can't I run this script (myshaper):
# myshaper - DSL/kabelmodem kimeno forgalmanak szabalyozasa.
# Irta: Dan Singletary (8/7/02)
minden nem-TCP
nem-TCP
mast nem
DEV=ppp0
RATEUP=120
RATEDN=1000
then
echo "[qdisc]"
tc -s qdisc show dev $DEV
tc -s qdisc show dev imq0
echo "[class]"
tc -s class show dev $DEV
tc -s class show dev imq0
echo "[filter]"
tc -s filter show dev $DEV
tc -s filter show dev imq0
echo "[iptables]"
iptables -t mangle -L MYSHAPER-OUT -v -x 2> /dev/null
iptables -t mangle -L MYSHAPER-IN -v -x 2> /dev/null
exit
tc qdisc del dev imq0 root 2> /dev/null > /dev/null
iptables -t mangle -D POSTROUTING -o $DEV -j MYSHAPER-OUT 2> /dev/null > /dev/null
iptables -t mangle -F MYSHAPER-OUT 2> /dev/null > /dev/null
iptables -t mangle -X MYSHAPER-OUT 2> /dev/null > /dev/null
iptables -t mangle -D PREROUTING -i $DEV -j MYSHAPER-IN 2> /dev/null > /dev/null
iptables -t mangle -F MYSHAPER-IN 2> /dev/null > /dev/null
iptables -t mangle -X MYSHAPER-IN 2> /dev/null > /dev/null
ip link set imq0 down 2> /dev/null > /dev/null
rmmod imq 2> /dev/null > /dev/null
then
echo "Shaping removed on $DEV."
exit
ip link set dev $DEV qlen 30
ip link set dev $DEV mtu 1000
tc qdisc add dev $DEV root handle 1: htb default 26
tc class add dev $DEV parent 1: classid 1:1 htb rate ${RATEUP}kbit
tc class add dev $DEV parent 1:1 classid 1:20 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 0
tc class add dev $DEV parent 1:1 classid 1:21 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 1
tc class add dev $DEV parent 1:1 classid 1:22 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 2
tc class add dev $DEV parent 1:1 classid 1:23 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 3
tc class add dev $DEV parent 1:1 classid 1:24 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 4
tc class add dev $DEV parent 1:1 classid 1:25 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 5
tc class add dev $DEV parent 1:1 classid 1:26 htb rate $[$RATEUP/7]kbit ceil ${RATEUP}kbit prio 6
tc qdisc add dev $DEV parent 1:21 handle 21: sfq perturb 10
tc qdisc add dev $DEV parent 1:22 handle 22: sfq perturb 10
tc qdisc add dev $DEV parent 1:23 handle 23: sfq perturb 10
tc qdisc add dev $DEV parent 1:24 handle 24: sfq perturb 10
tc qdisc add dev $DEV parent 1:25 handle 25: sfq perturb 10
tc qdisc add dev $DEV parent 1:26 handle 26: sfq perturb 10
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 20 fw flowid 1:20
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 21 fw flowid 1:21
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 22 fw flowid 1:22
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 23 fw flowid 1:23
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 24 fw flowid 1:24
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 25 fw flowid 1:25
tc filter add dev $DEV parent 1:0 prio 0 protocol ip handle 26 fw flowid 1:26
iptables -t mangle -N MYSHAPER-OUT
iptables -t mangle -I POSTROUTING -o $DEV -j MYSHAPER-OUT
20-26
iptables -t mangle -A MYSHAPER-OUT -p tcp --sport 0:1024 -j MARK --set-mark 23 # Alapertek az
iptables -t mangle -A MYSHAPER-OUT -p tcp --dport 0:1024 -j MARK --set-mark 23 # ""
iptables -t mangle -A MYSHAPER-OUT -p tcp --dport 20 -j MARK --set-mark 26 # ftp-data port, alacsony prioritas
iptables -t mangle -A MYSHAPER-OUT -p tcp --dport 5190 -j MARK --set-mark 23 # aol instant messenger
iptables -t mangle -A MYSHAPER-OUT -p icmp -j MARK --set-mark 20 # ICMP (ping) - magas prioritas, baratok ismertetojegye
iptables -t mangle -A MYSHAPER-OUT -p udp -j MARK --set-mark 21 # DNS nevfeloldas (kis csomagok)
iptables -t mangle -A MYSHAPER-OUT -p tcp --dport ssh -j MARK --set-mark 22 # secure shell
iptables -t mangle -A MYSHAPER-OUT -p tcp --sport ssh -j MARK --set-mark 22 # secure shell
iptables -t mangle -A MYSHAPER-OUT -p tcp --dport telnet -j MARK --set-mark 22 # telnet (ew...)
iptables -t mangle -A MYSHAPER-OUT -p tcp --sport telnet -j MARK --set-mark 22 # telnet (ew...)
iptables -t mangle -A MYSHAPER-OUT -p ipv6-crypt -j MARK --set-mark 24 # IPSec - viszont nem tudjuk, mi a "hasznos teher"...
iptables -t mangle -A MYSHAPER-OUT -p tcp --sport http -j MARK --set-mark 25 # helyi webszerver
iptables -t mangle -A MYSHAPER-OUT -p tcp -m length --length :64 -j MARK --set-mark 21 # kis csomagok (valoszinuleg csak ACK-k)
iptables -t mangle -A MYSHAPER-OUT -m mark --mark 0 -j MARK --set-mark 26 # redundans- jeloljunk minden nem jelolt csomagot 26-tal (alacsony prioritas)
echo "Outbound shaping added to $DEV. Rate: ${RATEUP}Kbit/sec."
# tavolitsd el a megjegyzest a kovetkezo sor elol, ha csak kimeno forgalomszabalyozast akarsz
# exit
modprobe imq numdevs=1
ip link set imq0 up
tc qdisc add dev imq0 handle 1: root htb default 21
tc class add dev imq0 parent 1: classid 1:1 htb rate ${RATEDN}kbit
tc class add dev imq0 parent 1:1 classid 1:20 htb rate $[$RATEDN/2]kbit ceil ${RATEDN}kbit prio 0
tc class add dev imq0 parent 1:1 classid 1:21 htb rate $[$RATEDN/2]kbit ceil ${RATEDN}kbit prio 1
tc qdisc add dev imq0 parent 1:20 handle 20: sfq perturb 10
tc qdisc add dev imq0 parent 1:21 handle 21: red limit 1000000 min 5000 max 100000 avpkt 1000 burst 50
tc filter add dev imq0 parent 1:0 prio 0 protocol ip handle 20 fw flowid 1:20
tc filter add dev imq0 parent 1:0 prio 0 protocol ip handle 21 fw flowid 1:21
iptables -t mangle -N MYSHAPER-IN
iptables -t mangle -I PREROUTING -i $DEV -j MYSHAPER-IN
iptables -t mangle -A MYSHAPER-IN -p ! tcp -j MARK --set-mark 20 iptables -t mangle -A MYSHAPER-IN -p tcp -m length --length :64 -j MARK --set-mark 20 # rovid TCP csomagok, valoszinuleg ACK-k
iptables -t mangle -A MYSHAPER-IN -p tcp --dport ssh -j MARK --set-mark 20 # secure shell
iptables -t mangle -A MYSHAPER-IN -p tcp --sport ssh -j MARK --set-mark 20 # secure shell
iptables -t mangle -A MYSHAPER-IN -p tcp --dport telnet -j MARK --set-mark 20 # telnet (ew...)
iptables -t mangle -A MYSHAPER-IN -p tcp --sport telnet -j MARK --set-mark 20 # telnet (ew...)
iptables -t mangle -A MYSHAPER-IN -m mark --mark 0 -j MARK --set-mark 21 # redundans- minden nem jelolt csomagot 21-el jelolunk (alacsony prioritas)
iptables -t mangle -A MYSHAPER-IN -j IMQ
echo "Inbound shaping added to $DEV. Rate: ${RATEDN}Kbit/sec."
I tryed to remove the comments because of the length.
I hope it will not be too long, sorry.
Why is there working with everybody else except me? I don't know what I have to do to get it work.
Please help me.
Ps: Is there any restrictions in the newest firmware?
Ps2: I don't have USB disk attached. Is there a problem?
