Results 1 to 5 of 5
Thread: Router does not reconnect - Solution?
    Jun 2004
    Hungary
    Question Router does not reconnect - Solution?
    Hi, I`m new here, I`ve just bought my wl500g, and using Oleg`s latest FW. /Thaks btw./
    I have ADSL with dynamic ip, and my ISP disconnects every 24h. And that is a problem, because the router doesnt tries to reconnect automaticaly, so I cant reach it from WAN.
    Can someone give me a hand, how to solve or work around the problem?
    What should I change in the FW /step by step/ ?
    Thanks in advance!
    Jun 2004
    Hungary
    Am I alone with this problem?
    Is it even supported by the wl500g or not?
    Did I missed to set up something?
    Nov 2003
    Eindhoven
    you should write a script that does reconnect every 24hour
    i believe you can use something with the commands SLEEP 86400
    refer to this thread
    https://wl500g.info/showthread.php?t=439
    please supply next time firmware number.. firmwares are released quickly sometimes so we can't know which one you are using.
    Jun 2004
    Hungary
    Thanks for the link, but I dont think it will help me. My ISP disconnects after some hour of using the internet, 2 or 3 times a day, in different times.
    The solution for me would that IF the router notices that pppoe is disconected, it tries to reconnect.
    So I would need a script that watches the state of the pppoe connection and if its disconnected, it reconnects.
    Could you help me with this?
    Its strange that it is not implemented in the official fw., other dsl routers have this default. /Why implement ftp, webcam, ddns, ... if on a disconnection you cant use any of them, beacause it does not reconnect????/
    ps.: FW version : Oleg's 1.7.5.9-2 (2004-06-19)
    Nov 2003
    Eindhoven
    well i'm not familair with any other WAN connection as DHCP as my provider just gives me DHCP and if you are not registered you get a screen to register with the provider when you try to access the internet.
    probably you can build a script (if it doesn't exist already) which checks the status of your PPPoE connection, and reconnects when dropped
    but i'm not familair with it so i don't know how it works
  1. Replies: 6
    Last Post: 23-07-2005, 14:12
  2. UnionFS, a solution for wl500g Ramdisk ?
    By WlanMan in forum WL-500g Custom Development
    Last Post: 10-03-2005, 15:38
  3. [VPN] PoPToP Implementing? or other VPN solution
    By tomaz in forum WL-500g Custom Development
    Last Post: 27-07-2004, 07:14
  4. [WIRELESS] wep 128 bit shared key solution?
    By Wisi in forum WL-500g Q&A
    Last Post: 02-04-2004, 11:02
