продолжение лога:
Jan 1 03:00:03 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 03:00:03 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 03:00:03 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 03:00:03 kernel: ipt_time loading
Jan 1 03:00:03 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 03:00:03 kernel: IPv6 v0.8 for NET4.0
Jan 1 03:00:03 kernel: IPv6 over IPv4 tunneling driver
Jan 1 03:00:03 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 03:00:03 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 03:00:03 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 03:00:03 kernel: FAT: bogus logical sector size 36864
Jan 1 03:00:03 kernel: NTFS: Unable to set blocksize 512.
Jan 1 03:00:03 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 03:00:03 kernel: Mounted devfs on /dev
Jan 1 03:00:03 kernel: Freeing unused kernel memory: 72k freed
Jan 1 03:00:03 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 03:00:03 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.37.0
Jan 1 03:00:03 kernel: PCI: Enabling device 01:02.0 (0004 -> 0006)
Jan 1 03:00:03 kernel: eth1: Broadcom BCM4318 802.11 Wireless Controller 3.90.37.0
Jan 1 03:00:03 kernel: vlan0: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 03:00:03 kernel: master interface
Jan 1 03:00:03 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 03:00:03 kernel: device eth0 entered promiscuous mode
Jan 1 03:00:03 kernel: device vlan0 entered promiscuous mode
Jan 1 03:00:03 kernel: device eth1 entered promiscuous mode
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering listening state
Jan 1 03:00:03 kernel: br0: port 1(vlan0) entering listening state
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering learning state
Jan 1 03:00:03 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 03:00:03 kernel: br0: topology change detected, propagating
Jan 1 03:00:03 kernel: br0: port 1(vlan0) entering learning state
Jan 1 03:00:03 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 03:00:03 dnsmasq[69]: started, version 2.22 cachesize 150
Jan 1 03:00:03 dnsmasq[69]: DHCP, IP range 192.168.1.2 -- 192.168.1.6, lease time 24h
Jan 1 03:00:03 dnsmasq[69]: DHCP, /tmp/dnsmasq.log will be written every 8h
Jan 1 03:00:03 dnsmasq[69]: read /etc/hosts - 4 addresses
Jan 1 03:00:03 dnsmasq[69]: reading /tmp/resolv.conf
Jan 1 03:00:03 dnsmasq[69]: using nameserver 195.14.50.21#53
Jan 1 03:00:03 dnsmasq[69]: using nameserver 195.14.50.1#53
Jan 1 03:00:03 kernel: usb.c: registered new driver usbdevfs
Jan 1 03:00:03 kernel: usb.c: registered new driver hub
Jan 1 03:00:04 kernel: usb-uhci.c: $Revision: 1.275 $ time 10:25:12 Jun 17 2006
Jan 1 03:00:04 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 03:00:04 kernel: PCI: Enabling device 01:03.0 (0000 -> 0001)
Jan 1 03:00:04 kernel: ECHI PCI device 30381106 found.
Jan 1 03:00:04 kernel: UCHI reg 0x41 = 10
Jan 1 03:00:04 kernel: UCHI reg 0x41 changed to = 0
Jan 1 03:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
Jan 1 03:00:04 kernel: usb-uhci.c: Detected 2 ports
Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 03:00:04 kernel: hub.c: USB hub found
Jan 1 03:00:04 kernel: hub.c: 2 ports detected
Jan 1 03:00:04 kernel: PCI: Enabling device 01:03.1 (0000 -> 0001)
Jan 1 03:00:04 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 03:00:04 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 03:00:04 kernel: PCI: Enabling device 01:03.2 (0000 -> 0002)
Jan 1 03:00:04 kernel: ehci_hcd 01:03.2: PCI device 1106:3104
Jan 1 03:00:04 kernel: ehci_hcd 01:03.2: irq 2, pci mem c00a7000
Jan 1 03:00:04 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 03:00:04 kernel: ECHI PCI device 31041106 found.
Jan 1 03:00:04 kernel: ECHI reg 0x49 = 80010f20
Jan 1 03:00:04 kernel: ECHI reg 0x49 changed to = 80010f00
Jan 1 03:00:04 kernel: ECHI reg 0x4b = 80010f09
Jan 1 03:00:04 kernel: ECHI reg 0x4b changed to = 80010f29
Jan 1 03:00:04 kernel: PCI: 01:03.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 03:00:04 kernel: ehci_hcd 01:03.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 03:00:04 kernel: hub.c: 4 ports detected
Jan 1 03:00:04 kernel: usb.c: registered new driver usblp
Jan 1 03:00:04 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 03:00:06 kernel: usb.c: registered new driver audio
Jan 1 03:00:06 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 03:00:06 kernel: Linux video capture interface: v1.00
Jan 1 03:00:06 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 03:00:06 kernel: Initializing USB Mass Storage driver...
Jan 1 03:00:06 kernel: usb.c: registered new driver usb-storage
Jan 1 03:00:06 kernel: USB Mass Storage support registered.
Jan 1 03:00:06 kernel: vlan1: Setting MAC address to 00 17 31 1b 02 a3.
Jan 1 03:00:06 kernel: VLAN (vlan1): Underlying device (eth0) has same MAC, not checking promiscious mode.
Jan 1 03:00:06 kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 03:00:06 kernel: vlan1: add 33:33:ff:1b:02:a3 mcast address to master interface
Jan 1 03:00:06 kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
Jan 1 03:00:07 pppd[95]: pppd 2.4.2 started by admin, uid 0
Jan 1 03:00:07 pppd[95]: Using interface ppp0
Jan 1 03:00:07 pppd[95]: local IP address 10.64.64.64
Jan 1 03:00:07 pppd[95]: remote IP address 10.112.112.112
Jan 1 03:00:08 pppd[95]: Starting link
Jan 1 03:00:09 pppd[95]: Serial connection established.
Jan 1 03:00:09 pppd[95]: Connect: ppp0 <--> /dev/pts/0
Jan 1 03:00:40 pppd[95]: LCP: timeout sending Config-Requests
Jan 1 03:00:40 pppd[95]: Connection terminated.
