Results 1 to 5 of 5
Thread: unslung cron ipkg problem
    Jun 2006
    England
    I installed the cron ipkg problem. However I'm having trouble getting it to start the cron daemon at bootup. I tried adding:
    /opt/etc/init.d/rc.unslung
    to /usr/local/sbin/post-boot
    and then just
    /opt/sbin/cron
    but neither seems to work.
    However if I use either of the commands, when I telnet or ssh in I can start the cron daemon.
    Anyone see what I'm missing?
    Jun 2005
    Slovenia
    MAybe
    Jun 2006
    England
    Quote Originally Posted by oleo
    MAybe
    If you mean at the start of /usr/local/sbin/post-boot. I already have that. It starts dropbear (the ssh server) but not the cron server started afterwards.
    Jun 2005
    Slovenia
    Mine config:
    $ cat /opt/etc/crontab
    SHELL=/bin/sh
    PATH=/sbin:/bin:/usr/sbin:/usr/bin:/opt/bin:/opt/sbin
    MAILTO=""
    HOME=/
    # ---------- ---------- Default is Empty ---------- ---------- #
    # m h dom mon dow user  command
    */30 *    * * *   admin nice torrent_watchdog
    */15 * * * * admin uptime >> /opt/var/log/uptime.log
    # 8am-7pm activity reports every 10 minutes during weekdays.
    #0 8-18 * * 1-5 admin /opt/lib/sa/sa1 600 6 &
    # 7pm-8am activity reports every an hour during weekdays.
    #0 19-7 * * 1-5 admin /opt/lib/sa/sa1 &
    # Activity reports every an hour on Saturday and Sunday.
    #0 * * * 0,6 admin /opt/lib/sa/sa1 &
    # Daily summary prepared at 19:05
    #5 19 * * * admin /opt/lib/sa/sa2 -A &
    $ cat /opt/etc/init.d/S10cron
    # Startup script for cron
    # Stop myself if running
    if [ -n "`pidof cron`" ]; then
        /bin/killall cron 2>/dev/null
    /opt/sbin/cron
    Jun 2006
    England
    Mine config:
    /opt/sbin/cron
    Thanks for that, the crontab gave me some ideas.
    My S10cron is the same. However the cron daemon
    doesn't get started at bootup.
    Here my /usr/local/sbin/post-boot
    # Activate swap
    swapon /dev/discs/disc0/part2
    # Start ssh server
    dropbear
    # Run all active services - active means starts with S
    #/opt/etc/init.d/rc.unslung
    # Start Cron
    /opt/sbin/cron
    The dropbear server starts ok at bootup but not the cron server. I also tried the commented /opt/etc/init.d/rc.unslung but that doesn't work either.
  1. Problem installing ipkg
    By the_slider in forum WL-500g Q&A
    Last Post: 29-06-2005, 08:35
  2. Problem with dieing AIR-connection
    By BòóN in forum WL-500g Q&A
    Last Post: 26-10-2004, 12:04
