Results 1 to 2 of 2
Thread: WL-300g dead! Reboot loop!
    Hi there,
    I have a big problem here: One of my WL-300g APs is in a reboot loop! Recover mode is still working, but no firmware flashed with the firmware restauration tool or with a TFTP client will boot up without the reboot loop... (OpenWRT RC5, Asus 1936, Oleg 1927-7c)
    I unfortunately flashed the wrong firmware and so I bricked the AP. But since the recover mode can still be entered, there should be a possibiliy to get the AP back to life again!?
    I've read that there is a possibility to recover the WL-500g in this case, but the two files mentioned (wl500g-clear-nvram.trx and wl500g-recover.trx) won't work with the WL-300g, I think. Perhaps someone can send me the right files for my WL-300g?! (I've also read that clearing the NVRAM on WL-300g is not safe, because default values won't be restored by the bootloader! Is this true? How can I clear the NVRAM to defaults then?)
    Thank you for your help!
    Peace,
    OllieW
    clear-nvram would work on this unit too.
  1. Reboot on ISP disconnects ?
    By 7111 in forum WL-500g Q&A
    Last Post: 27-09-2006, 09:18
  2. Eigenes Script nach reboot mitstarten
    By triple in forum German Discussion - Deutsch (DE)
    Last Post: 16-05-2006, 22:12
  3. my harddisk close to being dead
    By mutejute in forum WL-HDD Q&A
    Last Post: 11-03-2006, 23:44
  4. Nach REBOOT wird die "post-boot" Datei nicht ausgeführt
    By Trebron in forum German Discussion - Deutsch (DE)
    Last Post: 02-02-2006, 16:20
