Originally Posted by Oleg
i used wget to get my linux iso from http
when all my pc's where shut off it was downloading fine at my router..
Removed to save space. I've not seen any objectives to leave it in the firmware.
You need to change busybox config & recompile firmware.
Uff, its more that I can do at the moment, I only started with linux a couple of weeks ago (mainly becouse of this wl500).Originally Posted by Oleg
I was playing with snmp stuff and found this: http://voidmain.is-a-geek.net/files/ipkg/INSTALL . Since there's no ipkg support (yet?!) I was trying the 2nd method with wget... Then I'll try to install it manually.
get this file: http://files.wl500g.info/asus/wl500g...pp/busybox.zipOriginally Posted by rdude
unzip and upload to your (flash)disk@wl500g, afaik this is an earlier busybox version and should not be used to replace current busybox
e.g. use it as follow:
Code:./mnt/usbfs/busybox wget http://files.wl500g.info/asus/wl500g...pp/busybox.zip
Can you help me on changing the busybox version? I need to change the read-only file system and i have no clue how to do this.
amd2600 Ati 9700pro wl500g and lots more.....
just use harddrive or flashdrive for storing such things
the busybox executable is WAY TOO BIG to fit
that's it then! thnxz. I haven't been able to make my routerwork from HD yet. Too difficult ........... ;-)
Where is the bussybox.zip now located? Need wget too :-)
http://files.wl500g.info/asus/wl500g/firmware/app/Originally Posted by alpha5
