Results 1 to 3 of 3
Thread: use WLAN as WAN connection ?
    Hi
    Is there any way where I can use the WiFi interface as a WAN connection and routing traffic to the LAN interface on the router?
    Specifically I want to use a WL-HDD as a small router, connecting to the internet with WiFi.
    Setup :
    Internet <----> Wireless Router <----> WL-HDD ---> Client(s) Using Wired Connection.
    I dont want WDS mode, as I want the Client(s) totally separated on a different subnet than the one on the "indeside" of the Wireless Router.
    This would mean I need the WL-HDD to operate in Client Mode on the Wireless side, and routing all traffic to the LAN interface.
    How are settings like this possible in Olegs firmware?
    I tried setting the wan_ifname, wan_ifnames, lan_ifname and lan_ifnames variables "correctly" - but I cant seem to get the wireless interface connecting to my Wireless Router.
    macsat
    This possible in the same way, as with all wl500g family: switch it to home gateway mode and select Ethernet Bridge on the Wireless | Advanced page.
    This wont work perfectly I think.
    This will still make eth1 and eth2 be in a bridge, with the same IP.
    What I need is to make a LAN on a different subnet like this :
    Wireless Router <--- 192.168.1.X network Wireless ---> WL-HDD <-- Wired: 10.0.0.xx network.
    In order to be able to broadcast stuff to the LAN (eth1) side of the WL-HDD only, that the wifi network cannot see.
    Basically I need the wifi interface and lan interface to have separate IP addresses on different subnets, and I can then use iptables to route between the two networks.
    macsat
  1. pppd падает через 5-6 часов.
    By densen2002 in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 21-10-2008, 21:10
  2. Wan connection timeout / Wan port dies (solution)
    By twoblink in forum WL-500g Custom Development
    Last Post: 06-02-2006, 19:04
