I just flashed to this firmware and have the following problem (although I fear that it is not really firmware-related as I have experienced this with the two latest Asus releases as well )
I start from scratch after a factory reset with the quick setup. The only things I choose/enter are ADSL/PPPoE and user name/password. After the restart I am connected to the internet. If I do another restart without any changes by clicking on one of the finish buttons in the web interface, I am no longer connected to the internet and do not seem to be able to get there.
The log shows:
Jan 1 01:00:15 syslog.notice klogd: klogd started: BusyBox v1.00-pre7 (2004.06.14-19:28+0000)
Jan 1 01:00:15 user.warn klogd: CPU revision is: 00024000
Jan 1 01:00:15 user.warn klogd: Loading BCM4710 MMU routines.
Jan 1 01:00:15 user.warn klogd: Primary instruction cache 8kb, linesize 16 bytes (2 ways)
Jan 1 01:00:15 user.warn klogd: Primary data cache 4kb, linesize 16 bytes (2 ways)
Jan 1 01:00:15 user.warn klogd: Linux version 2.4.20 (root@omnibook) (gcc version 3.0 20010422 (prerelease) with bcm4710a0 modifications) #24 Mon May 3 20:52:46 MSD 2004
Jan 1 01:00:15 user.warn klogd: Determined physical RAM map:
Jan 1 01:00:15 user.warn klogd: memory: 01000000 @ 00000000 (usable)
Jan 1 01:00:15 user.warn klogd: On node 0 totalpages: 4096
Jan 1 01:00:15 user.warn klogd: zone(0): 4096 pages.
Jan 1 01:00:15 user.warn klogd: zone(1): 0 pages.
Jan 1 01:00:15 user.warn klogd: zone(2): 0 pages.
Jan 1 01:00:15 user.warn klogd: Kernel command line: root=/dev/mtdblock2 noinitrd init=/linuxrc
Jan 1 01:00:15 user.warn klogd: CPU: BCM4710 rev 0 at 125 MHz
Jan 1 01:00:15 user.warn klogd: Calibrating delay loop... 82.94 BogoMIPS
Jan 1 01:00:15 user.warn klogd: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 01:00:15 user.warn klogd: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 01:00:15 user.warn klogd: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:15 user.warn klogd: Checking for 'wait' instruction... unavailable.
Jan 1 01:00:15 user.warn klogd: POSIX conformance testing by UNIFIX
Jan 1 01:00:15 user.warn klogd: PCI: Fixing up bus 0
Jan 1 01:00:15 user.warn klogd: PCI: Fixing up bridge
Jan 1 01:00:15 user.warn klogd: PCI: Fixing up bus 1
Jan 1 01:00:15 user.warn klogd: Initializing RT netlink socket
Jan 1 01:00:15 user.warn klogd: Starting kswapd
Jan 1 01:00:15 user.notice klogd: NTFS driver v1.1.22 [Flags: R/O]
Jan 1 01:00:15 user.warn klogd: pty: 256 Unix98 ptys configured
Jan 1 01:00:15 user.notice klogd: Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Jan 1 01:00:15 user.warn klogd: Physically mapped flash: Swapping erase regions for broken CFI table.
Jan 1 01:00:15 user.notice klogd: number of CFI chips: 1
Jan 1 01:00:15 user.notice klogd: Flash device: 0x400000 at 0x1fc00000
Jan 1 01:00:15 user.notice klogd: Physically mapped flash: squashfs filesystem found at block 949
Jan 1 01:00:15 user.notice klogd: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 01:00:15 user.notice klogd: 0x00000000-0x00040000 : "pmon"
Jan 1 01:00:15 user.notice klogd: 0x00040000-0x003e0000 : "linux"
Jan 1 01:00:15 user.notice klogd: 0x000ed760-0x003e0000 : "rootfs"
Jan 1 01:00:15 user.notice klogd: 0x003f0000-0x00400000 : "nvram"
Jan 1 01:00:15 user.notice klogd: 0x003e0000-0x003f0000 : "config"
Jan 1 01:00:15 user.warn klogd: ip_conntrack version 2.1 (128 buckets, 1024 max) - 344 bytes per conntrack
Jan 1 01:00:15 user.warn klogd: ip_conntrack_pptp version 1.9 loaded
Jan 1 01:00:15 user.warn klogd: ip_nat_pptp version 1.5 loaded
Jan 1 01:00:15 user.warn klogd: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 01:00:15 user.warn klogd: ipt_time loading
Jan 1 01:00:15 user.warn klogd: FAT: bogus logical sector size 34816
Jan 1 01:00:15 user.err klogd: NTFS: Unable to set blocksize 512.
Jan 1 01:00:15 user.warn klogd: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 01:00:15 user.warn klogd: Warning: unable to open an initial console.
Jan 1 01:00:15 user.warn klogd: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 01:00:15 user.warn klogd: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.50.21.10
Jan 1 01:00:15 user.warn klogd: eth1: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.50.21.10
Jan 1 01:00:15 user.warn klogd: PCI: Enabling device 01:02.0 (0004 -> 0006)
Jan 1 01:00:15 user.warn klogd: eth2: Broadcom BCM43XX 802.11 Wireless Controller 3.50.21.10 (Compiled in . at 20:53:00 on Jan 21 2004)
Jan 1 01:00:23 user.warn klogd: lp driver: get device ID
Jan 1 01:00:23 user.warn klogd: neg fail
Jan 1 01:00:27 user.warn klogd: Register User Space Key Handler : 464 0
Any ideas?
