Hello,
I just find out why my wl500gx produces a lot of following errors during heavy load.
kernel: I/O error: dev 08:01, sector 12
kernel: SCSI disk error : host 0 channel 0 id 0 lun 0 return code = 70000
kernel: I/O error: dev 08:01, sector 789
it's caused by unshielded wire conecting my internal 2,5'' 40 GB toshiba hd with asus mineboard. After opening casing, when cable was not so close to board, everything was fine. I change cable for shorter and shielded one, add additional 100uF cabacitor neer to HD and now everything works fine, even when i run 10 screen sessions copying a lot of data .
regards
Krzysiek
