Results 1 to 4 of 4
Thread: Will there files enable me to restore default firmware?
    Question Will these files enable me to restore default firmware?
    First of all: what an absolutely great support forum, this!
    Before flashing my new wl-hdd2.5 with new firmware, I would like to have a way back. The firmware that was installed by default (1.2.3.6) is nowhere to be found on the 'net.
    Here Oleg and others explain how to copy the firmware to a file; this I have done, through busybox.
    This yields 2 files:
    3866624 flash
    262144 pmon
    Will these files enable me to go back to the current state, for example through a standard firmware update? Or do i simply cat them back to where they came from? This is something that has not become clear to me.
    Or am I missing something and is there a far better way to backup my current firmware for later use?
    Thank you for your help!
  2. Hello ,
    You should find that a firmware restoration utility came bundled with your WL-HDD 2.5.
    Thumbs up Yes, but...
    ... the current firmware version is not on the CD (1.2.3.6).
    So my quiestion becomes, is it possible to use the files I save in the manner described above, as an 'image' to feed to this firmware restore utility?
    Smile Any ideas?
    Does anyone have the answer to my question?
    To rephrase: Using telnet and this post I have created two files on the hard disk of my WL-HDD / WL-HMD:
    flash, 3866624 bytes
    pmon, 262144 bytes
    Can I use these files as input for the firmware flash tool? I am asking because the firmware version on my WL-HMD (Firmware 1.2.3.6, DMS (media server?) 1.1) cannot be found on the net and is not on the CD's in the box. I would really like the option of going back.
    Thank you! And sorry for kicking the thread up.
  1. Firmware upgrading HOWTO
    Last Post: 30-07-2008, 22:00
  2. Replies: 1
    Last Post: 20-06-2007, 10:38
  3. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 13:26
  4. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 11:01
    Last Post: 21-10-2004, 15:55
