Results 1 to 15 of 42
Thread: firmware of Wl-hdd on yakumo wireless Storage 60
    Want about $40 cheaper wl-hdd 60GB? See Yakumo Wireless Storage 60!
    High. See 100% identical product Yakumo Wireless Storage 60.
    http://www.yakumo.com/produkte/index...ss+LAN#1037087
    Jan 2005
    konstanz, germany
    Talking ... nice ... any experiences with fw diff to asus ?
    hi .-)
    NICE, but what about any differences to asus firmware?
    What about the price in germany ... could not find it anywhere .-( but i own a nice asus wlhdd ...
    Martin
    re:
    Wow, sorry, I was a little drunk last night. Not "high", but hi.
    I mean, firmware is totally the same, only with logo Yakumo (see manual). There's no reason you cannot upload aby other version of firmware (from ASUS, Oleg etc.). Price is about $200.
    Jan 2005
    konstanz, germany
    Talking cheaper ?
    Hi ...
    I got the asus wl-hdd2.5 from www.alternate.de for about 80 EURO (now only 69.- EURO) combined with a nice 80-100 GBs 2.5" HD (5400 U/min., 8MB cache, UMA-100) for about 100 EURO.
    @anarchist: your link is not available anymore ... no more restposten
    Good luck
    Martin
    Last edited by Martin1802; 15-08-2005 at 11:10. Reason: forgot something ... now some more infos
    Exclamation firmware of Wl-hdd on yakumo wireless Storage 60
    Hey guys ,
    i got the yakumo wireless storage 60 and i want to put the asus wl-hdd firmware on it because the device is the same but the yakumo firmware is kind of limited ... when i try to upgrade over the interface it says
    Firmware Upgrade Fail !
    Firmware upgrade fail. It may result from incorrect image, error transmission, or low memory level. Please check the version of firmare, reboot system and try again.
    Can you help me upgrading ?
    Thx for your replies
    Feb 2006
    Asus firmware on Yakumo
    Quote Originally Posted by surfingrace
    Hey guys ,
    Hi, first at all: asus firmware runs on Yakumo, because itīs the same! Initially you can not upgrade via Yakumoīs setuppage!
    Itīs a little bit tricky to install - you have to know how. And thatīs my way (there was one weekend of trying):
    - download last original ASUS firmware from internet, not the other versions from oleg
    - assign a fixed IP Adress for Yakumo Wireless Storage 60 in Setuppage, such as 192.168.001.015
    - put Yakumo Wireless Storage 60 on LAN (by cable!, wireless doesnīt work)
    - press the button on back of device at least 5 seconds until the power lamp turns of, after some seconds all lamps are off: the device is off
    - pull the power cable
    - press and hold the button an put the power cable in, wait some seconds until the power lamp start to blink, release the button
    - device is now in "update"-mode
    - start the software "firmware restoration" from Yakumo utility directory
    - insert the path to the downloaded asus firmware
    - press upload -> the upload should be start
    - after this procedure you and rebooting your device you can go the the setup page and you will see the asus wl-hdd setup
    - from this point you can install all other firmware versions including the ons from oleg via the setup page
    - if you like to use the drive with twonky: it runs, no problem
    Any questions?
    flupps
    thanks flupps , i tried it but i don`t know how long to hold the button pressed longer than 20 seconds ?
    Thanks in advantage
    Feb 2006
    Thanks in advantage
    pressing button on power ON:
    device off: ca. 5 sec -> all lamps go off
    factory settings and reboot: ca. 20 sec -> power lamp starts blinking fast (about 5 times)
    pressing button on power OFF and LAN-cable pluged:
    "Update"-Mode: ca. 5 sec -> power lamp start blinking slow and permanently
    flupps
    dammit , why doesn`t it do it ?
    Update yakumo
    Quote Originally Posted by flupps
    Any questions?
    flupps
    I have two questions:
    1) why change IP adress?
    2) when the update is done the IP adress must to be change again?
    many thanks.
    Feb 2006
    Quote Originally Posted by 20fifi05
    many thanks.
    You have not to change the IP adress, you have to set a fix IP adress! After boot process the Yakumo canīt get a adress from server, so it must have an own adress.
    flupps
    Can confirm that it works. Could flash Olegs FW on Yakumo (via flashing it to ASUS).
    I could also install ipkg, nano and hdparm (with is essential for me). But saving
    /usr/local/sbin to flashfs (so does all the chances are kept after reboot) obviously failed.
    I don't get an error message while
    flashfs save
    flashfs commit
    flashfs enable
    but after reboot all is lost. Can someone help me with that? Any workaround possible? Please help!
    Another issue: Why does the realtime clock doesn't work anymore. It's not a killer feature for me, but nice to have.
    taking on that old thread I bricked my yakumo by trying to flash the asus fw on it via the previously installed openwrt-kamikaze
    situation now:
    - can't reach it when in normal mode (silent on interface)
    - can ping it (but nothing else) in blinking/recovery mode (fix 192.168.1.4 IP as before)
    I found asus recovery tool on the asus webpage, device finder sends out some broadcasts into the world and some into the subnet (port 9999) but the device doesn;t answer, even if I can ping it.
    tried the asus fw restoration tool but it actually sends out nothing on the interface (several interfaces on the PC but all disabled or unplugged!, route print shows subnet route to the proper interface)
    tried to tftp to the device, but it doesn't answer.
    any hints?
    Found a solution:
    tftp 192.168.1.4
    tftp> binary
    tftp> get ASUSSPACELINK\x01\x01\xa8\xc0 /dev/null
    tftp> put <filename.trx> ASUSSPACELINK
    according to http://oldwiki.openwrt.org/OpenWrtDo...)Flashing.html
  1. [HowTo] Getting started (Firmware upgr, Storage, Samba, SSH)
    By hezik in forum WL-500g/WL-500gx Tutorials
    Last Post: 26-08-2008, 12:52
  2. Firmware upgrading HOWTO
    Last Post: 30-07-2008, 22:00
  3. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 13:26
  4. Flashing Oleg's Firmware in WL HDD
    Last Post: 21-10-2004, 15:55
