hi .-)
NICE, but what about any differences to asus firmware?
What about the price in germany ... could not find it anywhere .-( but i own a nice asus wlhdd ...
Martin
High. See 100% identical product Yakumo Wireless Storage 60.
http://www.yakumo.com/produkte/index...ss+LAN#1037087
hi .-)
Martin
Wow, sorry, I was a little drunk last night. Not "high", but hi.
I mean, firmware is totally the same, only with logo Yakumo (see manual). There's no reason you cannot upload aby other version of firmware (from ASUS, Oleg etc.). Price is about $200.
Hi ...
I got the asus wl-hdd2.5 from www.alternate.de for about 80 EURO (now only 69.- EURO) combined with a nice 80-100 GBs 2.5" HD (5400 U/min., 8MB cache, UMA-100) for about 100 EURO.
@anarchist: your link is not available anymore ... no more restposten![]()
Good luck
Martin
Last edited by Martin1802; 15-08-2005 at 11:10. Reason: forgot something ... now some more infos
Hey guys ,
i got the yakumo wireless storage 60 and i want to put the asus wl-hdd firmware on it because the device is the same but the yakumo firmware is kind of limited ... when i try to upgrade over the interface it says
Firmware Upgrade Fail !
Firmware upgrade fail. It may result from incorrect image, error transmission, or low memory level. Please check the version of firmare, reboot system and try again.
Can you help me upgrading ?
Thx for your replies
Hi, first at all: asus firmware runs on Yakumo, because it´s the same! Initially you can not upgrade via Yakumo´s setuppage!Originally Posted by surfingrace
It´s a little bit tricky to install - you have to know how. And that´s my way (there was one weekend of trying):
- download last original ASUS firmware from internet, not the other versions from oleg
- assign a fixed IP Adress for Yakumo Wireless Storage 60 in Setuppage, such as 192.168.001.015
- put Yakumo Wireless Storage 60 on LAN (by cable!, wireless doesn´t work)
- press the button on back of device at least 5 seconds until the power lamp turns of, after some seconds all lamps are off: the device is off
- pull the power cable
- press and hold the button an put the power cable in, wait some seconds until the power lamp start to blink, release the button
- device is now in "update"-mode
- start the software "firmware restoration" from Yakumo utility directory
- insert the path to the downloaded asus firmware
- press upload -> the upload should be start
- after this procedure you and rebooting your device you can go the the setup page and you will see the asus wl-hdd setup
- from this point you can install all other firmware versions including the ons from oleg via the setup page
- if you like to use the drive with twonky: it runs, no problem
Any questions?![]()
flupps
thanks flupps , i tried it but i don`t know how long to hold the button pressed longer than 20 seconds ?
Thanks in advantage
Hi,Originally Posted by surfingrace
pressing button on power ON:
device off: ca. 5 sec -> all lamps go off
factory settings and reboot: ca. 20 sec -> power lamp starts blinking fast (about 5 times)
pressing button on power OFF and LAN-cable pluged:
"Update"-Mode: ca. 5 sec -> power lamp start blinking slow and permanently
flupps
dammit , why doesn`t it do it ?
Please write what you have done.Originally Posted by surfingrace
flupps
i pressed the button 5 sec ... shutdown
then i pulled the powercable pressed the button again and i put the power cable back in and hold the button 5 sec
Thats fine. Do you have plugged the LAN cable? Without the cable network connection it doesn't works.
Flupps
yes its plugged in but it doesnt work
Do i have to plug it directly into my pc ? because now its plugged into a switch
