have you specified Hostname in the IP settings page?
Thanks Oleg for your fast reply:
I put the address manually on XP, so the DHCP is off on the router.
With this configuration on windows XP, I must assign manually the address of the DNS server.
In the first address (DNS1): the address of the router,
In the second(DNS2): nothing
I put also the address of the router for the "passerelle" (hostname, i suppose).
I have also an old PC with W98 : exactly the same problem! all the addresss are put manually.
On the ASUS (DNS and WINS) :
DNS1: nothing,
DNS2: the address of the router (in grey, I can't modify it),
WINS: nothing.
DHCP : no.
Without changing anything on windows XP and on the configutation of the router, when I downgrade to the previous version (CR4), all is OK!!!! and all was OK with all your previous firmwares (and also with from ASUS).
Best regards,
Alain.
Also, please post the system log begining with "unable to open initial console" message.
I'm not really interested in statistics, more in realtime troughput so i can view my up/download in kb or mb (my provider does store statistics)Originally Posted by Oleg
If it's a deamon it's oke if there is a win32 client for it![]()
Statistics would be great. A Lite version of Darkstat?
Only with throughput and traffic consumption by IP and without graphs.
I used to have it on my GW and it was very usefull and very light.
I am very new with the WL500g. I got it last week. I flashed the latest FW
Firmware 1.7.5.6 CR5 [Oleg] and try to get samba running with my 128mb usb1.1 stick. I know this type of usb stick works on the wl500g. It is formatted on the PC with fat (32/16 i don't know)
My problem is that I can not get the samba running after entering the nvram settings and reboot. I also set thet hostname.
cat /var/log/nmb: empty
cat /var/log/smb
Get_Hostbyname: Unknown host WLServer.
No interface found for address 68.51.191.42
Get_Hostbyname: Unknown host. WLServer
The ip above I don't know... not my adsl modem...not the wl500g IP....?
The IP is also not responding to a ping.
If I type telnet [hostname] it works ok......
I tried it running the wl500g in homegateway mode and now in ap only...but nothing. Is there alo a possibility to change the workgroup on the wl500g?
have a look at www.mijnip.nl there you can see your 'external' ipOriginally Posted by rcire
Hi, Sorry I also forgot to say that it is not my ADSL IP.
So FTP on this flash drive works also OK, but still get samba not running.
same message in log file.
/mnt/ramfs/etc # cat /etc/hosts/
cat: /etc/hosts/: No such file or directory
/mnt/ramfs/etc #
Please execute this coomand and post the output
Code:cat /etc/hosts
Hello
I have update to the actually firmware, and after the reboot my Webinterface are offline (at all ports).
W-LAN, Routing and DHCP are running
Remove extra slash, i.e. /etc/hosts and not /etc/hosts/Originally Posted by rcire
Same story:
/mnt/ramfs/etc #
How you've configured wl500g? Does it run in AccessPoint or Home Gateway mode?
Hello,
I have just put Firmware 1.7.5.6 CR5 [Oleg], and here is my dysfunction:
- I cannot print any more on my HP printer psc 2400 while he(she,it) work with the firmware 1.7.5.6
- for my Web cam Logitech Quickcam Zoom, there has one can of better, now I arrive has to connect me to the server, on the other hand I have no image of displayed, I just have a grey image with subscriber below to the right in the daytime and the hour.
- samba works correctly, but I have of big slowing down during the browsing in directories or loss of the shared link.
If you have ideas to adjust my problemes, I am a buyer.
Thanks to all
I don't think we can make much out of your story, the printer thing is clear but the rest looks like abracadabraOriginally Posted by Nibe
For the printer, on this location you can find a howto for win2k or XP.
http://wl500g.dyndns.org/printing/
