Results 46 to 50 of 50
Thread: [USB] Memory Sticks
  1. #46
    Nov 2004
    Sweden
    Tested: NOT WORKING
    Reason: It can not be partitioned but with FAT/FAT32 only.
    Model: WL-500G
    Firmware: 1.9.2.7-7b
    Device
    Brandname: Micro Memory
    Brandtype: Micro Memory
    Memory: 512 MB
    USB Interface: USB 2.0 compliant
    URL To manufacturer/product: http://www.247-help.com
  2. #47
    Apr 2005
    Slovak Republic
    A-data Pd4 1 Gb
    Tested: WORKING
    Model: WL-500g Deluxe and WL-500g Premium
    Firmware: 1.8.2.1 (WL-500g Deluxe)
    Brandname: A-DATA
    Brandtype: My Flash
    Model: PD4 (Alu Body)
    Memory: 1 GB
    USB Interface: USB 2.0 (Backward compatible with USB 1.1)
    URL of product : http://www.adata.com.tw/adata_en/pro...p?ProductNo=86
  3. #48
    Jan 2006
    Slovakia
    Apacer Handy Steno AH220
    Tested@
    Model: WL500g.Deluxe
    Firmware: 1.9.2.7-7f
    Device WORKING
    Brandname: Apacer
    Brandtype: Handy Steno AH220
    Memory: 2GB
    USB Interface: High-speed USB 2.0 certified, backwards compatible with USB 1.1
    URL To manufacturer: http://www.apacer.com/
    URL To product: http://www.apacer.com/en/products/Ha...H220_specs.htm
  4. #49
    A-Data C801 16GB
    Tested: WORKING
    Model: WL-500g Premium v2
    Firmware: 1.9.2.7-d
    Brandname: A-DATA
    Brandtype: Classic Series
    Model: C801
    Memory: 16GB
    URL of product : http://www.adata.com.tw/en/product_s...ctNo=AC81ZZZWH
  5. #50
    Thumbs up Kingston Data Traveler 102 (DT102/16GB)
    Tested: WORKING
    Model: WL-500W
    Firmware: 1.9.2.7-d-r1222 (from wl500g project at Google Code)
    Tested: NOT WORKING
    Model: WL-500W
    Firmware: 1.9.2.7-10
    Device
    Brandname: Kingston
    Brandtype: Kingston Data Traveler 102 (DT102/16GB)
    Memory: 16GB
    URL To manufacturer: http://www.kingston.com/
    URL To product: http://www.kingston.com/flash/dt102.asp
    Notes:
    Does not work with Oleg's firmware 1.9.2.7-10; there I get "I/O error: dev 08:00, sector 0" and the device is unusable. It works perfectly with WL500W-1.9.2.7-d-r1222. Mke2fs was very slow, but overall performance is fine.
    I'm using ext2 instead of ext3 because various sources say the journal writes in ext3 wear out flash more. The firmware doesn't include ext2fs support; the module is found in the modules file which is listed on the firmware download page. I put the module (ext2.o) in flashfs. I load it and mount the filesystem from /tmp/local/sbin/post-boot
  1. Replies: 0
    Last Post: 22-08-2005, 12:33
  2. 2 usb sticks
    By kamilek in forum WL-500g Q&A
    Last Post: 03-08-2005, 09:23
  3. USB memory stick not available
    By hejira in forum WL-500g Q&A
    Last Post: 06-06-2005, 12:47
  4. Memory upgrade?
    By Yzord in forum WL-500g Q&A
    Last Post: 16-03-2005, 11:26
  5. Help, problem with USB sticks
    By zipper in forum WL-500g Q&A
    Last Post: 05-03-2005, 16:46
