Decompress it and type make. If everything is ok the build process will be completed in several minutes saying "You can now try your new firmware linux.trx ... bla-bla-bla".
But if you need to change modules/kernel this is something tricky - you need to compile them separately and copy to the directory with my sources. So full build looks like this:
- decompress ASUS sources
- patch ASUS kernel with the 1.7.5.6-1 kernel patch (to add the et modules support)
- patch the same source tree with 1.7.5.6-3 kernel patch (to add all the remaining stuff)
- execute "make mrproper" in the kernel tree
- copy .config file from my sources
- execute "make oldconfig" or "make menuconfig"
- once configured type "make bzImage modules modules_install DEPMOD=true"
- once completed mips modules will be in the /lib/modules/2.4.20 (so if you've something in this directory it will be lost..)
- copy modules to "extra" directory in my sources (check to see it's layout)
- copy arch/mips/brcm-boards/bcm947xx/compressed/vmlinuz to the piggy.gz in build directory
- once you've completed type make in my dir
Regards,
Oleg.
