You can use the following command to temporarily disable STP on the bridge:
To disable it permanently, you have to change a value in nvram:Code:brctl br0 stp off
Code:nvram set lan_stp=0 nvram commit
Hello everyone!
I use my wl-500g-deluxe router since'05 november. With Oleg's latest firmwares (and the asus 1.9.5.0 firmware too) the lan leds are flashing about every two seconds. I have 3 PCs connected to the router through lan cable. I started an ethereal and says these packets belongs to the spanning-tree protocol.
How can I disable this, not to flashing the leds?
With the asus 1.9.4.0 firmware this was not a problem, so the leds did not flash.
I am not a unix guru, but I tried the "set spantree disable all" command, but nothing happend. Maybe this is not a valid unix command.
Please note that english is not my native language, but hope you can understand me.
Originally Posted by wtzm
Thank You!
Problem solved.
BTW on my WL-500g this command works:Originally Posted by wtzm
And you can check the status:Code:brctl stp br0 disable
Code:brctl show br0 stp
Sorry for causing confusion - I swapped "br0" and "stp". It must of course read:
(disable does not work for me. YMMV - I'm using bridge-utils-1.0.6 on OpenWrt...)Code:brctl stp br0 off
