Unfortunately I can't swap the WRT54G and WL300g, WRT must be as an AP and WL300g-s as clients (I set AP mode to "AP only", and Extended mode to "Ethernet Bridge"). Once again, your 1.8.1.7-3 firmware works well in this configuration and relays the PPPOE frames, but the 1.9.2.7-7a doesn't relay.Originally Posted by Oleg
The only two features why I would like to use 1.9.2.7-7a, the SMTP daemon and the working WPA-PSK in AP-client mode.
Janos
