Page 9 of 19 FirstFirst ... 7891011 ... LastLast
Results 121 to 135 of 271
Thread: Firmware v1.9.2.7 CR7 now 7g [Oleg]
  1. #121
    Quote Originally Posted by SurJector
    if you do not wish to publish this diff.
    I do not have such diff at all.
  2. #122
    Sorry I'm too elliptic, what I meant was: if you do not wish to spend the additional time and effort to make and publish this diff, I'll patch my source firmware alone. I hoped that it was easy for you to compute and publish that diff, that's all (fon instance: the linux kernel is published both in ``complete tarbal''l and ``patch with respect to the last version'', so that you can patch incrementally; it's obvisouly an additional hurdle for you and probably not useful for many people except (maybe) oleo and myself). If you keep the last version of the source tree it might be easy to do, so that I'd be happy to have such a diff, otherwise, let's forget my request.
    SurJector
  3. #123
    Quote Originally Posted by dunatos
    Don't use it because it make my wan port die!
    I have WL-500G and AT&T is the isp. It was working with all the previouse 7a,7b,7c. After upgrade to 7d, it won't connect to internet. Back to 7c, everything is O.K. The log seems normal and it show connect, but just won't load the web page.
  4. #124
    Quote Originally Posted by jycai
    confirmed. same prb here. any clue?
    thx in advance
  5. #125
    Guys, post your system logs, please. Which connection type you've selected in the WAN settings? Static/DHCP/...?
  6. #126
    thx for ur reply.
    WAN connect by DHCP
    syslog with PM
    thx
  7. #127
    So far no problems with 1.9.2.7-7d. Working fine
  8. #128
    Quote Originally Posted by knoes
    thx for ur reply.
    WAN connect by DHCP
    syslog with PM
    thx
    Hm... According to your syslog, everything is OK, and you've pppoe connection, not dhcp. Also, this log is not for -7d version for sure... Please flash -7d and save correct log.
  9. #129
    syslog7d by PM (sorry my fault)
    on 7c again to sent this stuff
    greetz a. thx
  10. #130
    greetz a. thx
    According to your logs, you're running wl500g deluxe (not the wl500g). Also, according to your logs the box is connected to your ISP and working fine. Could you please clarify your problems?
    Also, your connection type is PPPoE, not DHCP!
  11. #131
    installed .trx file - WL500gx-1.9.2.7-7d
    connection type is - PPPoE
    ISP connection is established though, no access to websides neither mail
    flashing back to 7c all is working as it should without changing any settings.
    greetz
  12. #132
    Try to figure out the reason, i.e. from your PC type:
    nslookup www.wl500g.info
    ping www.wl500g.info
    tracert www.wl500g.info
    if something failed - telnet to router and type
    traceroute www.wl500g.info
    Post your results here.
    P.S. I've PPPoE connection to my ISP, everything is working fine.
  13. #133
    C:\Documents and Settings\opaold>nslookup www.wl500g.info
    Server: my.router
    Address: 192.168.1.1
    Non-authoritative answer:
    Address: 87.239.8.20
    C:\Documents and Settings\opaold>ping www.wl500g.info
    Pinging www.wl500g.info [87.239.8.20] with 32 bytes of data:
    Request timed out.
    Request timed out.
    Request timed out.
    Request timed out.
    Ping statistics for 87.239.8.20:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
    C:\Documents and Settings\opaold>tracert www.wl500g.info
    Tracing route to www.wl500g.info [87.239.8.20]
    over a maximum of 30 hops:
    1 2 ms <1 ms <1 ms my.router [192.168.1.1]
    2 * * * Request timed out.
    3 * * * Request timed out.
    4 * * * Request timed out.
    5 * * * Request timed out.
    6 * * * Request timed out.
    7 * * * Request timed out.
    8 * * * Request timed out.
    9 * * * Request timed out.
    10 * * * Request timed out.
    11 * * * Request timed out.
    12 * * * Request timed out.
    13 * * * Request timed out.
    14 * * * Request timed out.
    15 * * * Request timed out.
    16 * * * Request timed out.
    17 * * * Request timed out.
    18 * * * Request timed out.
    19 * * * Request timed out.
    20 * * * Request timed out.
    21 * * * Request timed out.
    22 * * * Request timed out.
    23 * * * Request timed out.
    24 * * * Request timed out.
    25 * * * Request timed out.
    26 * * * Request timed out.
    27 * * * Request timed out.
    28 * * * Request timed out.
    29 * * * Request timed out.
    30 * * * Request timed out.
    Trace complete.
    over telnet:
    [opaold@(none) root]$ nslookup www.wl500g.info
    Server: www-proxy.K1.srv.t-online.de
    Address: 217.237.150.97
    [opaold@(none) root]$ ping www.wl500g.info
    PING www.wl500g.info (87.239.8.20): 56 data bytes
    64 bytes from 87.239.8.20: icmp_seq=0 ttl=57 time=50.7 ms
    64 bytes from 87.239.8.20: icmp_seq=1 ttl=57 time=51.2 ms
    64 bytes from 87.239.8.20: icmp_seq=2 ttl=57 time=50.3 ms
    64 bytes from 87.239.8.20: icmp_seq=3 ttl=57 time=50.
    [opaold@(none) root]$ traceroute www.wl500g.info
    traceroute to www.wl500g.info (87.239.8.20), 30 hops max, 40 byte packets
    1 * * *
    2 217.0.74.2 (217.0.74.2) 41.147 ms 41.47 ms 40.55 ms
    3 ams-e4.AMS.NL.net.DTAG.DE (62.154.15.2) 47.279 ms 47.686 ms 48.114 ms
    4 so6-2-0.mpr3.ams1.nl.above.net (62.4.65.25) 47.679 ms 47.501 ms 48.205 ms
    5 pos-8-0.cr1.ams2.nl.above.net (64.125.31.14) 48.423 ms 48.265 ms 48.479 m
    s
    6 grafix.ams4.nl.above.net (82.98.253.68) 48.861 ms 85.999 ms 48.938 ms
    7 rtr-1.rtd-kub.grafix.nl (217.67.232.141) 58.514 ms 217.67.247.5 (217.67.247
    .5) 50.192 ms 50.305 ms
    8 web00.intention.nl (87.239.8.20) 51.173 ms 50.695 ms 50.204 ms
    greetz
  14. #134
    Please telnet to router (with 7d running), type
    iptables -vnL
    iptables -t nat -vnL
    and post output...
  15. #135
    Ok, the reason is the empty WAN ip address field. Wait a bit for 1.9.2.7-7e.
  1. Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
    Last Post: 09-02-2006, 09:19
  2. Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
    Last Post: 18-06-2005, 12:07
  3. Firmware v1.9.2.7 CR3c [Oleg]
    Last Post: 12-03-2005, 09:07
  4. Firmware v1.9.2.7 CR3 - Now CR3b [Oleg]
    Last Post: 01-02-2005, 14:31
  5. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
