There is nothing to do on the wl500g side.
You've to configure your Windows boxes and firewalls on the PCs.
I now use the WL500g as a wireless internet gateway, print server and fot ftp. There are two laptops connected (wifi) and a desktop (wired).
I would like to install a home network through the WL500, while not losing the internet gateway function. Is this possible? I don't fully understand the different options in the tab "System Setup - Operation Mode" of the setup page. The radio button "Home gateway" is now marked. Should I use one of the other options? Router? Access point?
I installed shared folders, but on "My network" I can't see any of the other computers appearing.
What should I do next to create a local network?
frimware is: 1.9.2.7-6b
Cheers,
René
Thanks Oleg, I'll do just that.
Thanks for your reply & keep up the good work.
I admire your firmware programming!
Cheers,
René
