AFAIK the raw printing does only work in the custom firmware releases ? I'd try to flash the latest version and try again.
I'm trying to set up my HP Laserjet 1320 via the Wireless routers USB port. The Router states that the printer is online, and shows the correct model name. However, when I try to set it up using the Printer Setup Wizard it cannot find any server. I tried to fill inn values which I found in a post from Oleg - using RAW, IP 192.168.1.1 and so on - but no luck.
Anyone have any ideas?
Running Windows XP SP2, and the firmware is 1.8.2.1
