Try this firmware. Once started it's ifups wired LAN iface, set it to 192.168.1.1/255.255.255.0 and launchs telnetd. No password required to access it. You need to setup your PC with static address, something like 192.168.1.2. Try to telnet to wl500g, to check it's booted. After that you could examine your nvram using "nvram show".
I will try it now, thank you all for being so helpful.
I tried now, the router boots and I can telnet to it. When I write nvram show I see a lot of settings for the router. Don't really know what to look for. Tried to install a newer firmware after this without success.
Ok. At least it's alive. ;-) You need to look thru it to find something unusual using
or try this one to reset to defaults:
after that you should be able (i've not verified this) to install regular firmwares
IT WORKS IT WORKS.
I don't know how to thank you. But I really appreciated this.
Thank You
Maybe we should add the restoration firmware to the others.
//Adam.
So, nvram_x default did the trick?
- You may not post replies
- You may not edit your posts
Forum Rules
