shortcut PIN10
Hi there,
I've tried almost everything after an unsuccesful firmware upgrade.
Finally I want to try the dirty way (
shortcut PIN10 of the FLASH (AMD) chip with GROUND while powering on, release immediately. The unit should now enter recovery modus
(power led wil flash))
Can anybody tell me where I can find this pin at my WL-HDD?
many thanks
Ollie
tech doc amd
I found a paper wirh the descriction of the chip.
http://www.amd.com/us-en/assets/cont...cs/23579c5.pdf
After shortening the chip, my WL-HDD woke up!
Ollie
is it possible to show a photo here where you mark the pins on the board. I think that would be useful for all other users.
Regards
DJans
- You may not post replies
- You may not edit your posts
Forum Rules
